Need help to remove manual transmission from a nissan maxima 2001!
Does someone have some intructions of how to remove a manual transmission from a nissan maxima 2001 , do i really need to get the engine down to remove the transmission?
No I wouldn't think so. I did my auto which I'd say is probably a little bigger then a manual on jack stands. Get the car up as high as you can. Take wheels off axels out crossmember down. Once you get that far, it's probably a little different with manual but same concept. Once you get the trans separated I brought it out the drivers side.
It's not much different from other front drive cars.
You don't need to drop the engine but you'll need to support the engine and remove the cradle that runs under it front to rear. It helps to be able to tilt the motor when lining up the transmission to reinstall it. It's a tight fit so you don't have a lot of room to align it without hanging it on the input shaft.
Are you doing this on a lift or on the floor?
Are you using air tools or just hand tools?
Have you pulled a front drive tranny before?
You might want to get a copy of the Haynes manual for the car too.
I've done manuals and autos without dropping the engine.
So drop the engine down. With all the mounts removed except for pass side, lower it until the motor hits the unibody.
josephbolden91
10-29-2015 07:02 AM
