2002 wont start
Old Jan 9, 2016 | 11:15 AM
johnaschon's Avatar
2002 wont start
My 02 clicks when you turn the key started out intermittent. I replaced the inhibit relay and the starter still the same problem. Anyone have any ideas?
Old Jan 9, 2016 | 11:29 AM
maxiiiboy's Avatar
If your starter clicks, but does not turn the engine, then this is usually a starter problem. Most often, the starter solenoid is faulty. Also, it could be caused by a broken, disconnected or rusted wiring in the starter circuit, or starter pinion being jammed or broken. Check your battery: it should have 14-14.5V before you start cranking.
Old Jan 9, 2016 | 01:50 PM
DennisMik's Avatar
Typo on that battery voltage. The battery voltage should be 12 - 12.5V before you start.
Old Jan 9, 2016 | 09:09 PM
maxiiiboy's Avatar
Yes, Dennis is right, as usual. Except - it wasn't a typo, it was a mind slip.
Hurricanes10
Feb 1, 2016 12:06 AM
Rich96
Jan 12, 2016 04:45 PM
jlee
Jan 8, 2016 06:54 PM
Jaimee1402
Jan 7, 2016 08:22 AM
jmlee44
Jan 4, 2016 08:42 AM
