Starter Issue and yes I searched.
Old Jan 16, 2016 | 11:28 PM
Ms. Harden's Avatar
Ok guys before everyone gets all up in arms i have spent a whole day searching and cant find my exact problem. I am traveling and just need the help so I apologize if I overlooked it.
2000 Maxima GXE 5 speed M/T 162k miles HIDs are the only Mod. Replaced my starter about a month ago with a brand new one. A day or so ago it began to make a strange noise on the first starting attempt. The sound is the same as if the car is running and you turn the key to the start position. On the second start attempt it cranks up fine no problem. Optima battery just tested fine and the alternator as well.
Could this be a relay issue?
I read the TSB that comes with the starter but I couldn't find the blue relay on the fender wall
The relay box in front of the battery's diagram has rubbed off but on the row closet to the battery there is a brown square relay and a blue rectangle one. Is this one of them?
Thanks in advance
Old Jan 17, 2016 | 04:56 AM
Turbonut's Avatar
When you say brand new starter, brand new, remanufactured and where purchased?
Old Jan 17, 2016 | 07:31 AM
Derrick2k2SE's Avatar
It sounds like the starter solenoid is working too slowly. It's supposed to push the small gear on the starter into the ring gear on the flywheel THEN start spinning to turn the motor over. If it actuates too slowly, the gear will be spinning by the time it tries to mesh with the flywheel gear.
Sometimes this happens when the starter is old and wearing out. I'm guessing that this is a rebuilt starter and it's having a problem.
It doesn't sound like something that's going to strand you while you're traveling or cause any major damage. I'd warranty out that starter when you get home.
Old Jan 17, 2016 | 07:40 AM
Ms. Harden's Avatar
Not remain. Brand new. 11 tooth from Autozone
Old Jan 17, 2016 | 07:45 AM
Ms. Harden's Avatar
Your rationale definitely matches the sound i am hearing. I was under the impression it was a new starter when I picked it up but that box went back with the core so who knows. Glad it won't strand me but considering that I have a short ram intake and it is just two bolts i will warranty it out for sure. Thanks
Old Jan 17, 2016 | 07:49 AM
Ms. Harden's Avatar
Since it's not switching between power and no power to the starter the relay is probably still OK right?
Old Jan 17, 2016 | 07:55 AM
Turbonut's Avatar
If you had to return the core, it's a remanufactured starter, and with the AZ reputation for
electrical components, just return it and hopefully the next one will be better.
A few years ago my son purchased a reman from AZ for his Toyota, 3 starters later he got his
money refunded and purchased a starter from another, more reputable, supplier.
Old Jan 17, 2016 | 08:20 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Yep, never buy moving parts from Junkozone.
No issues with the one I've got from Advance (80 bucks with code and tax).
Brand new TYC on Amazon for 73. I know that's way cheaper than local stores.
Old Jan 17, 2016 | 08:41 AM
^^this^^ If you gave a core, it's a reman.
There's only one relay for the starter and it's obviously getting power. If not, it wouldn't do anything. The starter gets a signal and handles everything internally. If it's not working right it's the starter.
They'll have to test the one you return and it may not fail in their test. If they say it passes tell them it's "intermittent" and stand your ground. They have to include a "failed" slip from their test machine in order to process a return. They can, and will, force it to fail if they have to.
Old Jan 18, 2016 | 09:42 PM
Ms. Harden's Avatar
OK good to know.
Old Jan 18, 2016 | 09:43 PM
Ms. Harden's Avatar
Well ill be ****** but you live and you learn. I'll look into the TYC one too. Heck 73 $ and no hassle is a win for me.
Old Jan 18, 2016 | 10:41 PM
maxiiiboy's Avatar
The TYC starter is $66.79 on Rockauto.com, plus shipping.
Old Jan 19, 2016 | 05:53 AM
maxipower's Avatar
i went thru the same problem with a rebuilt starter ,,only lasted 9 months ,,then i got a brand new starter from http://www.partsgeek.com/catalog/200...l/starter.html
no core return and i took the rebuilt starter apart to see what was inside,,found all burnt old parts ,,,wasteful ,,,it s worth to add extra bucks for a new starter ,,,scroll down on this website and there s some new starters..good luck
Old Jan 19, 2016 | 01:38 PM
Bad *** Newb
That's why I use amazon - free shipping (and I have free prime LOL).
Old Jan 21, 2016 | 08:52 PM
manilakid3's Avatar
I bought my new starter aftermarket from amazon for around $60. Cranks up as if it was a new car. Still works great 2 years after.
I'd stay away from autozone parts. Look for parts on amazon or ebay, the reviews are almost always spot on and usually free returns/exchange.
Old Jan 26, 2016 | 02:44 AM
Ms. Harden's Avatar
Quick update
So a few days in and it took 4 mins to start the car. When my Husband took it to AZ and let the guy hear it he initially said "oh that's the flywheel". LOL on what planet does the flywheel start turning before the starter engages? Anyway he soon realized he want talking to dummies and quickly exchanged the part. So far so good but new starter week be ordered next week. I'll probably put the AZ starter on ice.
Tequila
Dec 6, 2015 08:29 PM
Donkeypunch
Nov 9, 2015 11:18 AM
who4ever
Nov 9, 2015 09:23 AM
Dieseldan
Nov 6, 2015 10:38 AM
