Blue Long Life Antifreeze
Old Feb 17, 2016 | 10:50 PM
manilakid3's Avatar
I'm thinking of using this instead of the green oem. Does anyone know how long will this coolant last till another change?
Also, I found a 50/50 mix on amazon. What should be the procedure when flushing the system? Since about 4 quarts of water will still be in the engine when doing the flush. Or does anyone know where to find the non diluted blue coolant? TY
Old Feb 18, 2016 | 10:04 AM
mclasser's Avatar
If you're doing a flush, you'll need full strength coolant otherwise you won't get a proper 50/50 mixture in the end. Nissan coolant is only sold as 50/50 which sucks.
Pep Boys recently started stocking full strength Asian-spec coolant made by Rechochem. It's blue like Nissan LL and can go 5 yrs/150K miles. I wish that stuff was around when I changed my rad. Make sure to only use distilled water.
Old Feb 18, 2016 | 12:26 PM
FanaticMadMax's Avatar
I have only seen the blue antifreeze on late model Hondas, but on Nissan? unless they are doing them on late models. I know our 5 gen are like yellowish green color, I bought the Zeryx from Napa which are for Asian vehicles for the early 2000's
Old Feb 18, 2016 | 12:30 PM
manilakid3's Avatar
I'll check out Rechochem. TY
Old Feb 18, 2016 | 12:31 PM
manilakid3's Avatar
My 7th gen Maxima has blue coolant. Hows the Zerex?
Old Feb 18, 2016 | 01:17 PM
manilakid3's Avatar
Napa has the Zerex but only pre-dilutted. They do have one thats not diluted but its Dexcool orange. I hope you don't have that in your car. Dexcool orange is bad for our engines.
Old Feb 18, 2016 | 01:27 PM
manilakid3's Avatar
Hows the Peak yellow coolant? Its both Silicate and Phosphate free.
Old Feb 18, 2016 | 03:32 PM
Will's Avatar
I've uses the Peak one once w/o issues, as well as Prestone, but I recently went back to OEM and mixed it myself. The normal green coolant should be good enough. I used to drain and refill my rad once a year so the system always has fresh coolant, but scaled it back to every other year now. There's a drain plug on the bottom of the rad, and try to buy the spill-free funnel made by Lisle when refilling and burping air out to make the job no-mess.
Old Feb 18, 2016 | 05:15 PM
manilakid3's Avatar
The Peak comes with just the concentrate as well with the premix. TY
Old Feb 18, 2016 | 07:38 PM
RA030726's Avatar
I'm nutty for Nissans
They do sell the blue in a concentrated version 999MP-L255QTP, 1 quart bottle. It's meant to replace 20% of the factory 50/50 for colder climates. It lowers the freezing point from -34°f to -62°f. While not full strength it will help to get a better ratio if you have too much water.
Old Feb 18, 2016 | 09:29 PM
manilakid3's Avatar
To do a complete flush would cost you $95 just for the coolant. Whoa
Old Feb 18, 2016 | 09:58 PM
manilakid3's Avatar
Pepboys have the green concentrate coolant with No silicate, amine, and borate. Sounds good to me.
$21.99
https://www.pepboys.com/product/details/879918/01036
Old Feb 18, 2016 | 10:12 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Seems pointless when Prestone extended life is free of silicate, phosphate, borate and nitrate (and universally compatible).
Old Feb 18, 2016 | 10:29 PM
manilakid3's Avatar
I had a look at the new Prestone coolant at Walmart but the label doesn't say anything about silicate, phosphate or borate free. Not even on their site.
Old Feb 18, 2016 | 10:36 PM
manilakid3's Avatar
OEM Green
- no silicates and amines: protects water pump seals
- no borate: protects aluminum corrosion and pitting
Old Feb 19, 2016 | 12:28 AM
Bad *** Newb
Prestone (and most other major brands) AF2000 is an OAT coolant (2-EHA formula). It's basically dex and since it's OAT, it's NAP free.
If it's an extended life coolant (green, yellow or orange), then it's the same crap.
It doesn't matter anyway. If you're mixing with distilled water, then there's no chance of precipitates.
We don't have soft HGs or the ones coated with plastic, so coolant doesn't really matter as long as it's not in there so long that it becomes acidic.
If you have money to burn, then you can buy Zerex (HOAT).
I stick by my comment in another thread. Coolant is coolant.
Old Feb 19, 2016 | 02:16 PM
RA030726's Avatar
It's not meant to be used on it own.
Old Feb 19, 2016 | 06:18 PM
maxiiiboy's Avatar
.... you'll need full strength coolant otherwise you won't get a proper 50/50 mixture in the end. Nissan coolant is only sold as 50/50 which sucks.
Not true. I just bought a gallon of Nissan 100% coolant. I paid $27.99 (incl. 8.25% tax) here in the Bay area.
Old Feb 19, 2016 | 09:18 PM
manilakid3's Avatar
Where? I need to pick some up tomorrow. Do you know a place in San Jose? TY
JoeWhit
May 12, 2019 09:32 PM
Levsimus
Apr 13, 2016 10:25 PM
richard300
Mar 15, 2016 09:47 AM
seesole
Feb 17, 2016 08:24 PM
97_GXE
18
Feb 17, 2016 04:10 PM
