Unbearable noise in front end of car
Old Feb 18, 2016 | 04:39 AM
Octo's Avatar
I have a 2000 Maxima SE.Last morning my car started making this loud whining, grinding agaisnt something noise coming from the front end of the car.
Only happens when im in drive or reverse. Never in idle. Also, while in park, I hear a little tick tick tick sound also. Regardless, the sound is unbearable and it sounds like my car will lock up if I even try to drive on it. Any help with this matter would be appreciated cause I have to take a bus and Uber to work .
Old Feb 18, 2016 | 06:52 AM
NmexMAX's Avatar
dot dot dot ...
How are the drive belts doing? Mine did this when my idler pulley was on its way out. Just in case, any oil in the engine and it's condition and how's the tranny fluid being that this only occurs in a drive gear?
Old Feb 21, 2016 | 02:36 PM
zenjia 03merlot's Avatar
if i had to guess, grinding sound = bearings. r/r them in pairs, i just did all four at once. if you can,do a '12-6' and '9-3' push/pull to check for play on your tires, while car is jacked up. should be no play.
while in there, may as well check all your connections points and boots for deterioration/failure in your in the front end:
ball joint, cv boots both inner and outer, tie rod ends, front sway bar end links, front sway bar bushings
fronts have to pressed into knuckle, which require some wrench skills, removing the axles, etc. the rears are cake, r/r. if you have ABS brakes, just make sure to get the abs with tone ring, otherwise you will get a abs yellow light in dash as you pass 80mph.
Old Feb 21, 2016 | 03:00 PM
george__'s Avatar
Maybe your chain is done
BobMax
19
Feb 29, 2016 07:15 PM
kirkhilles
Jan 27, 2016 06:25 AM
BobMax
Jan 1, 2016 12:00 PM
5thgendriver
Dec 15, 2015 01:31 PM
