P0430 whats the best aftermarket precat?
Old Feb 20, 2016 | 02:44 PM
Maximum Performance's Avatar
My car (2002 6MT) is throwing P0430 and my front pre-cat is rattling
which of the aftermarket alternatives is the best quality/price wise? pretty easy to replace?
Old Feb 20, 2016 | 03:08 PM
mclasser's Avatar
Walker seems to be a trusted brand.
Old Feb 21, 2016 | 12:52 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Best cat is no cat
I wouldn't drive it. It has already started doing damage. There's no point making it worse.
Old Feb 21, 2016 | 08:46 PM
which part number is it?
WALKER 82584
or WALKER 16362
Old Feb 22, 2016 | 04:33 AM
Turbonut's Avatar
Depending on emission equipment and location, but probably 16362
Old Feb 22, 2016 | 05:44 AM
TallTom's Avatar
WALKER 82584
or WALKER 16362
The 16362.
The 82584 is the same cat but CARB approved for the folks like us whose state demands only CARB cats can be installed (and more expensive). Currently only New York and Cali.
Old Feb 22, 2016 | 07:17 AM
Originally Posted by TallTom
The 16362.
Cool, I am in IL so the cheaper part works, as long as the quality is decent and will last a few more years
any of you that bought the walker part, did you have to buy any additional gaskets or hardware? is it pretty easy to replace?
Old Feb 22, 2016 | 02:09 PM
TallTom's Avatar
I didn't put on a replacement precat (I had my stock ones gutted) but new gaskets were needed. From watching the guy, it was a PITA to take out and put back in so you may want to buy replacement bolts as well.
Old Feb 23, 2016 | 02:56 AM
losifanatic's Avatar
I had to use a torch to cut mine out. It's was completely rusted
Old Feb 29, 2016 | 10:41 AM
after doing more research I am having hard time to decide between the eastern or walker cat
do both need both new gaskets?
Old Feb 29, 2016 | 10:50 AM
cdoublejj's Avatar
just about any part needs a new gasket
Old Feb 29, 2016 | 08:30 PM
yeah but I was wondering if any if them came with gaskets or not?
walker specifies the lower gasket needs to be purchased separetly
Old Mar 28, 2016 | 12:52 PM
Moenaim55's Avatar
Catalytic converter
Hi I have a 6th gen maxima and my car threw a p0430 code up for bank 2 and I was just curious what would happen if I just cut the cats out and put some piping instead. I know it's illegal but just curious. Thanks
Old Mar 28, 2016 | 01:00 PM
I'm running headers so basically it's the same thing. You need to get an o2 Sim or antifoulers for the secondary o2 so it won't throw a code
Old Mar 29, 2016 | 06:40 AM
TallTom's Avatar
Since you have a 6th gen, just get some high flow pre cats.
http://www.racinglineperformance.com...&idcategory=24
Old Mar 29, 2016 | 08:42 AM
Bad *** Newb
6th gen looks easy to gut.
Stop spending money on worthless cats, please.
Fun fact: Looks like Nissan never actually got new cats for 6th gen. There's plenty of pics of them broken and clogging the Y pipe.
Old Apr 18, 2016 | 06:37 PM
rich6661's Avatar
Is the WALKER 82584 a bank 2 replacement cat on a 2000 Max?
Old Apr 18, 2016 | 08:06 PM
maxinout93's Avatar
I just bought an eastern brand cat and it comes with two gaskets and screws.
Old Apr 19, 2016 | 06:40 AM
Itz Shak's Avatar
Looks like a petition needs to be started against these cats.. Save the Maximas!
Old Apr 19, 2016 | 07:31 AM
NmexMAX's Avatar
dot dot dot ...
Best cat is no cat
I also vote no cat ... gutting. Or headers.
Old Apr 19, 2016 | 07:35 AM
TallTom's Avatar
I don't think they are going to do much about a 13-16 year old car.
Old Apr 19, 2016 | 10:21 AM
Itz Shak's Avatar
I don't mean with Nissan, im talking about the owners lol.
Old Apr 20, 2016 | 09:25 AM
rich6661's Avatar
Question...the secondary O2, is that the one just after the bank 2 pre-cat?
I ask because I replaced that O2 sensor and it didn't clear the code, so would the anti-foulers be of any good?
Old Apr 20, 2016 | 10:41 AM
maxinout93's Avatar
Yes that is the 02 sensor right below the cat, I believe you have to use an antifouler, or extended 02 bung to get rid of the code.
Old Apr 21, 2016 | 08:13 AM
Prophecy99's Avatar
op is prolly long gone,
but how do u know that is what it is rattling? if u have thta bees in the can noise it can be and more likely serpentine belt idler pulley
Old Apr 21, 2016 | 05:15 PM
maxinout93's Avatar
lol
Old May 16, 2016 | 11:35 AM
I sent it back, let it rattle, dont wanna deal with taking it off, when I drive mostly highway it works fine, no check engine light
Old May 16, 2016 | 01:18 PM
Bad *** Newb
Start shopping for a new car. You were warned.
Old May 16, 2016 | 06:49 PM
It has been rattling for over 2 years 25k+ miles, I had this car for 13 years, I think I am due for a new car ha-ha
Old May 20, 2016 | 05:59 PM
maxinout93's Avatar
Why not just replace it, its very easy to do, especially the front pre cat. You may just be able to keep the car for a few more years. Just a suggestion, not trying to tell u what to do.
Old May 20, 2016 | 06:24 PM
Bad *** Newb
He can just dump it out, it's IL. They give no ****s about emissions. If you're in one the few counties that requires testing, then a nonfouler solves it.
Yes, it will literally fall out when you turn it upside down lol.
I read this year they're not requiring testing for some b/c of the budget LOL.
Old May 20, 2016 | 06:39 PM
maxinout93's Avatar
Just wanted to know before i order if this is the correct size 02 sensor bung on ebay.http://www.ebay.com/itm/161119594890?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old May 20, 2016 | 07:32 PM
Bad *** Newb
Yes, it's the right size. I do not know if having the other one drilled out will keep the code from popping. I (and everyone pretty much) leave it undrilled, so it's restricted.
I would buy a normal set at the auto parts store and use them with these. That way you get a set for each cat and have the restriction needed.
Use lots of anti-seize. These will rust quite a bit.
Old May 20, 2016 | 08:59 PM
maxinout93's Avatar
Oh ok so these just screw into the original 02 sensor holes right? And then you install the 02 sensor into the extended bung?
Old May 26, 2016 | 07:38 AM
Dlowe90's Avatar
On a p0430 type code, what're the chances its actually just the 02 sensor going bad? My car as 150k miles and has the 0430 code. Is it more likely the 02 sensor or the cats or should I just replace both sensors and the cat just to be safe and not have to worry about it again any time soon?
Old May 26, 2016 | 12:36 PM
Itz Shak's Avatar
Most likely to be bad pre cats at that mileage, especially if it's the year 02-03
Old May 26, 2016 | 02:28 PM
Dlowe90's Avatar
Would it be both pre cats or would it just be the left (front) one for that specific bank? (it is an 03, unfortunately!)
Also, is there any chance any of you guys know the bolt sizes for the bolts that go from the manifold into the pre-cat as well as the bolts that go from the pre-cat into the y-pipe? While I'm at it I figured I might as well go ahead and replace all the bolts.
Old Jun 2, 2016 | 12:28 PM
collije's Avatar
I'd have a similar question. 2k1 GLE auto, have the P0430 code. Will the Walker mate to the OEM exhaust as well?
Max16SR
Jul 29, 2019 09:27 PM
lowriderman3
Oct 4, 2016 11:55 AM
hithesh
Feb 20, 2016 02:10 PM
maxinout93
Feb 20, 2016 06:31 AM
