Stalling
Old Feb 23, 2016 | 09:01 PM
03Alt3.5Biz's Avatar
Stalling
I have a 2000 5 speed Maxima SE that operates well except occasional stalling while coming to a stop after the car is fully warmed up. When stopping and pushing in the clutch the idle will drop below 500rpm and the car will shake. It doesn't stall much but it's on the edge of stalling.
Some detail: fairly new air filter, newer plugs, TB bypass a few weeks back, no codes.
Old Feb 24, 2016 | 12:36 AM
webjohn's Avatar
Maf
Old Feb 24, 2016 | 06:24 AM
cornholio's Avatar
iacv
Old Feb 24, 2016 | 08:37 AM
Heel Til I Die's Avatar
Sounds like the MAF. I had the same problem with my '00 MT. I replaced it with OEM. You have a 2000 so the part isn't too expensive. I replaced it and mine runs fine now. The knock-off replacements didn't last. A bad MAF won't necessarily throw any codes.
Did you replace the air filter with K&N or some other type of oiled filter? I remember reading somewhere that if the filter is over-oiled, then it can mess up the MAF.
If you change the MAF, make sure you reset the ECU (disconnect the neg battery cable for 24 hours). If you're still having issues, you can try the idle relearn, but it's tricky to get just right.
Old Feb 24, 2016 | 02:13 PM
I still use a stock air filter, not an oiled version. Where do u recommend I buy a maf for best pricing and reliability? How much do u estimate it will be?
Old Feb 24, 2016 | 03:02 PM
Derrick2k2SE's Avatar
I would check for vacuum leaks before spending money on a MAF. Stumbling at idle but running fine at higher RPM is a classic symptom of a vacuum leak.
I'm not saying it isn't the MAF but checking for vacuum leaks is free and easy. It's the first thing I would do with a rough idle that wasn't throwing a code.
Old Feb 26, 2016 | 01:04 PM
An OEM MAF is usually somewhere in the neighborhood of $80-$100, but yes - absolutely look for vacuum leaks as well. It could be as simple as a $5 hose fix.
mclasser
36
Jul 23, 2024 01:11 PM
Hurricanes10
Feb 1, 2016 12:06 AM
kirkhilles
Jan 27, 2016 06:25 AM
Pnjboyzz
Jan 5, 2016 09:44 AM
mclasser
Dec 19, 2015 07:27 AM
