hey guys Transmission ? here on the 5th gens
Old Mar 19, 2016 | 06:49 PM
warchief337`'s Avatar
ok so i just had my tranny rebuild i have a 2001 20th anniversary SE apparently after rebuilding it it still had leaking and kept getting stuck in reverse so i took it back the guy said the transmission case is cracked and we have been looking all over to find one or just the rear part of one any have any good leads on the Transmission case for a 2001 SE 20th 3.0L ? any help is much appreciated. nissan dealers also dont sell the housings anymore
Old Mar 19, 2016 | 07:15 PM
Mattx's Avatar
In the "case" is that referring to the entire bell housing? I have a good hunch the mechanic over torqued the pan bolts. Which in turn probably cracked pieces of the bottom of the housing where the pan bolts to. Now you have a leaking mess. I'm speculating this based on what you've described. The likelihood it's leaking anywhere else is slim. If this is the problem your mechanic is trying to cover up his mistake. car-parts.com is a great site to find cheap transmissions is your area. I doubt you'll be able to get just a bell housing. I may be wrong though. More information would be a help. The entire housing is made of cast aluminum and the pan side is pretty brittle. It's very important not to over tighten those pan bolts. I hope this helps if not give some more info.
Old Mar 19, 2016 | 07:25 PM
Hey Mattx thanks for the info yah i think thats what happened too but he is playing for all the parts we are going to buy, he offered this himself and thanks for the website ima check it our right now.
Old Mar 19, 2016 | 10:29 PM
Mattx's Avatar
No problem. That's a stand up guy you have for a mechanic. Anybody can make a mistake but at least he's taking ownership of it and doing the right thing.
Old Mar 12, 2017 | 10:01 PM
Rinard Pratt's Avatar
5sp swap
Does anyone know if the 96 to 99 5sp manual transmission swap to a 2000 5sp manual with little effort. I aM having a little trouble finding a 2000-01 close by. But there are a few in the 96-99 model range within close proximity.
phoboi2006
Jul 23, 2016 08:45 PM
Pnjboyzz
Feb 9, 2016 09:01 PM
ANDY.VIP
Jan 27, 2016 09:08 AM
innofish
Jan 22, 2016 07:54 AM
