ABS problem?
ABS problem?
Hey,
I am having an issue with my ABS brakes on my 2000 maxima. They have worked before but now they aren't activating as well as they use too, so I am wondering if the sensor needs cleaning? Or is this another problem?
Thanks,
Maximusdriver
Thanks,
Maximusdriver
You're going to have to be specific of the symptoms.
If the pedal isn't soft and brake performance is good, then there's nothing wrong.
Are you testing in the wet?
The conditions you test it in will play a role too. Even trying it on a cool morning vs. a hot afternoon will affect the traction on same road.
Perhaps whom ever flushed the system didn't bleed the calipers in the correct order. I forgot to do the caliper order correctly and my brakes were squishy and my ABS/TCS was on all the time on a previous vehicle I owned. Brakes still worked and it was winter so I dealt with the lights.
EndoT800
Aug 28, 2018 01:34 AM
ameerhussain57
Apr 5, 2016 07:46 PM
mrdigray
Apr 5, 2016 02:14 PM
