Cranks but won't start
Old Apr 11, 2016 | 10:28 AM
2damax's Avatar
Hey guys it has been a long while since I have been here but having some real problems. My 2010 murano just lost the transmission so I am down to my 2003 maxima as a family car.
2003 maxima AT 195k miles. Car cranks but will not start. It has had code p0445 (EVAP leak) for a while and the starts having been taking longer and longer. Today it finally failed to start and is showing the EVAP code along with p1800.
Is there a common solution that causes a no start before I start any diagnostics?
Thanks for any help
Old Apr 11, 2016 | 10:40 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Thanks for any help
The codes are unrelated.
Try unplugging the crank sensor and see if it will start.
Old Apr 11, 2016 | 10:49 AM
2damax's Avatar
Ok I will jack the car up and unplug it now
Old Apr 11, 2016 | 11:09 AM
2damax's Avatar
Unplugged the harness (the one with the white dot right?) and the car still did not start. That **** was COVERED in oil though
Old Apr 11, 2016 | 11:28 AM
2damax's Avatar
So I put gas in the car and it started. Idk what made me add has since the meter says I have almost 1/4 tank. But at least it started
Edit: I filled the tank and it reads under 7/8 full
Old Apr 11, 2016 | 02:38 PM
MadMax SE's Avatar
not for nothing but mabye you should run an additive in the tank to possibly free the little unit that reads gas level. i read somewhere on here they can stick easily, or otherwise replace the pump. i only trust seafoam as my snake oil of choice. it has shown decent results when ive used it in the past.
Old Apr 11, 2016 | 02:46 PM
2damax's Avatar
I may try that but I did the diagnosis for my cluster per FSM and determined my gauge on the cluster itself is faulty. I believe it was the test on page 122 of the EL section.
Idk if I will even get a new cluster given the value of the car.
Old Apr 11, 2016 | 03:00 PM
MadMax SE's Avatar
Ouch, it's always electrical with these newer cars. Anyway, if you have access to the wires, you could jury rig a voltmeter into the gas gauge lines and read resistance as you fill up. Record resistance when you fill up and when you start bucking from low gas( don't attempt without a spare gallon of gas on hand) I saw it on this video called No ***** given rx7.
Old Apr 11, 2016 | 04:28 PM
Bad *** Newb
This happened to another member. It's lucky you guys made it home.
illvillecat99
23
Dec 4, 2016 01:57 PM
valerit1
May 19, 2016 04:13 PM
Max I am
Mar 9, 2016 03:12 AM
slickblack94
Feb 29, 2016 10:33 AM
