Clunk from Passenger side area
Old May 7, 2016 | 02:57 PM
  #41
andrei_condrea's Avatar
how can you tell if the noise comes from carrier bearing or axle?
the axles don't make any noise ( like click-click) when turning or when accelerating. there is a bit of play inboard-outboard in the axle, but it's the same play on the left side. i tried moving the axle up-down or fwd-back, no play.
and the crazy part is that it disappears under load from weight balance in curves. this is what drives me nuts.
Old Sep 18, 2016 | 07:11 AM
  #42
can someone tell me if some play is acceptable on the shaft (CV axle- passenger side), in the segment between the carrier bearing and the transmission housing(long straight shaft). it has slight play when i move it up/down. it's the only thing i can think of. the joints of the cv axle is solid and no play up/down and a bit of play in/out but this is normal. ( no clicking noises otherwise).
Old Sep 18, 2016 | 08:20 AM
  #43
mclasser's Avatar
Ah yes, the ever-elusive passenger side clunk!
Looks like OP replaced everything under the sun, to no avail. I've had the noise since getting the car 4 yrs ago. Never gets louder and only happens over certain bumps. I just live with it now.
Old Sep 18, 2016 | 10:36 AM
  #44
maximatech12's Avatar
try the sway bar end links.
I replaced my Passenger side DS and yes noticed some movement in the mid shaft before.
While replacing drive shaft the Steering knuckle puts a lot of pressure on the LCA and puts a lot of stress on the end links and Sabilizer bar.
JM AUTO RACING
Nov 21, 2017 08:24 AM
valerit1
May 19, 2016 04:13 PM
ColdCananda
Apr 15, 2016 01:13 AM
tmorales509
Feb 29, 2016 05:08 PM
ColdCananda
Feb 16, 2016 03:50 PM
