Help 2002 Maxima gle
Old Jul 20, 2016 | 01:45 AM
ro0obinnn's Avatar
Hi my Maxima starts fine the very first time but after that it starts but it dies. The rpm just drops but if I start it and press the gas then it won't die but the rpm is still below normal. It does drive normal afterwards. What can be the problem when it? Thanks in advance
Old Jul 20, 2016 | 03:50 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by madmax se
chances are it's your idle air control valve, mine does something similar because i bought a ebay cheapo one. I have to tap the gas after i start it as well to keep it running but only when its warmed up already. Mine still idles perfectly otherwise
2002...
Clean TB without moving the butterfly and do idle air relearn. Reset ECU and do the relearns if that doesn't seem to work. Check for vac leaks.
Old Jul 20, 2016 | 03:54 AM
MadMax SE's Avatar
2002...
Forgot that the 02 doesn't use the same valve as the 3.0, isn't the iat sensor on the tb aswell?
Old Jul 20, 2016 | 04:24 AM
Bad *** Newb
Negative. IAT is on the MAF sensor, but isn't used anyway. 3.5s don't have an IACV at all.
Old Jul 20, 2016 | 08:09 AM
mclasser's Avatar
2002...
Hopefully cleaning it won't do more harm than good. Seeing as these 5.5 TB's are sensitive little bastards, I'm afraid to even touch mine.
Old Jul 20, 2016 | 11:45 AM
Bad *** Newb
You can also have someone flip the key on/off while you spray it out.
Old Jul 20, 2016 | 10:10 PM
maxiiiboy's Avatar
Clean your MAF.
blackcyborg009
May 8, 2018 03:21 AM
valerit1
May 19, 2016 04:13 PM
brooklynboss22
Mar 9, 2016 04:45 AM
Max I am
Mar 9, 2016 03:12 AM
RussMaxManiac
Sep 6, 2000 06:13 AM
