Help with hub nut
Old Aug 13, 2016 | 08:55 AM
AEKnight's Avatar
Help with hub nut
Replaced front wheel bearing and now hub nut comes loose when driving. I torqued nut to spec. Should a new nut be used, heard they were self locking. Would blue thread locker work using old nut. Thanks in advance.
Old Aug 13, 2016 | 10:43 AM
DennisMik's Avatar
Every once in a while someone has this problem. There does not seem to be a "do this and you are good to go" solution. I don't think the nuts are self locking as new nuts spin freely on the axle. A self locking nut will not do this.
You could try thread locker, but you will have to let it sit for a while so that it is completely dry and set up before driving. Another possibility is to use a lock nut.
Old Aug 13, 2016 | 11:09 AM
AEKnight's Avatar
It wouldn't be a problem having the car sit for 24 hrs letting the thread locker set. Really surprised there isn't a castle nut on the axle. Not even a washer behind the nut. Guess I'll try the thread locker. I don't wanna over torque the nut and fry the new bearing, us know?
Old Aug 13, 2016 | 11:14 AM
AEKnight's Avatar
Glad to see you're still spending time on the .org. How's the Lexus treating you?
Old Aug 13, 2016 | 11:18 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Thread lock should work, but if it comes loose, then you haven't tightened it enough. Hammer it on with a good impact. Put that **** on at 250 ft lbs and you won't have a problem. Loose nuts = dead wheel bearings.
Old Aug 13, 2016 | 02:13 PM
DennisMik's Avatar
I'm finally used to driving the beast. It has one nasty blind spot in the right rear. Pickup trucks can hide in it, it is a real problem. It is pretty comfortable to ride in, though. Lexus has several problem areas. The power steering rack likes to go out. Inside, the plastic Toyota used doesn't hold up to sunlight. The dashboard cracks and the door panels melt. Toyota will fix it under an extended warranty, but it takes over a year to get parts.
Old Aug 13, 2016 | 05:49 PM
ManualMaxima's Avatar
5th Gen till she dies!
My hub nut would go loose after driving as well so it's not an uncommon occurrence (and I torque to spec). I over-torqued mine and its been fine for a few years now.
Levsimus
Apr 15, 2016 07:28 PM
ColdCananda
Apr 15, 2016 01:13 AM
maxinout93
Feb 20, 2016 06:31 AM
ColdCananda
Feb 16, 2016 03:50 PM
