Help after replacing MAF sensor
Old Sep 10, 2016 | 05:42 PM
drainwater's Avatar
So just swapped out the sensor today. Car runs alot stronger But it's struggling to maintain an idle ( typically low). Is the ecu relearn the next step? Or do I need to be looking at the idle air control ?
Old Sep 10, 2016 | 07:07 PM
flames101sully's Avatar
Did it have trouble maintaining idle before you replaced MAF? If it did then it would be good to check the idle control, if not then an idle relearn could possibly fix it.
Old Sep 10, 2016 | 07:31 PM
drainwater's Avatar
yea it did. Car was not allowing me to shift over 2500 rpms either. I thought for sure it was the MAF screwing up the whole fuel system.. But now I'm wondering if the Idle control is shot too..
Old Sep 11, 2016 | 11:12 AM
So does it as of now not go above 2500 Rpms? Doing a relearn won't hurt, and if that doesn't help it could possibly be the throttle position sensor. Not sure that the idle control would keep you below 2500 rpms.
Old Sep 11, 2016 | 02:21 PM
drainwater's Avatar
Sorry that response was confusing. The car is currently running above 2500 Rpms during normal driving again. But it currently isn't holding idle very well. Idling to high then going to normal then dropping in idle really low.
Old Sep 11, 2016 | 07:42 PM
cornholio's Avatar
if you have a 02 like you mentioned in another thread you have no iacv, so cross that off the list
Old Sep 12, 2016 | 03:46 AM
drainwater's Avatar
Haha awesome. That's helpful.
Old Sep 12, 2016 | 07:09 AM
Ok, try doing the idle relearn and get back to us. Hopefully thats it or it will be quite a lot harder to diagnose. Some other threads have said if not the MAF it could be an 02 sensor.
Old Sep 15, 2016 | 06:12 PM
drainwater's Avatar
It is showing a code for the o2 sensor but it was replaced recently.. Im gonna do the idle relearn tomorrow and get back to you.
Old Sep 15, 2016 | 07:24 PM
Child_uv_KoRn's Avatar
Bad *** Newb
reset ecu with pedal dance and see what happens, idle relearn if necessary
If primary O2, unplug it and see what happens if it's still not resolved. If seconday...you better be allotting time to gut precats.
Old Sep 16, 2016 | 12:19 PM
drainwater's Avatar
Its showing bank 2 sensor 2. Haven't gotten to the reset yet.. Waiting for wife to get off work. I have to pass emissions though. If I gut the cat will it still pass? They don't check to see if you have a cat though. Its all through the computer
ejenzo
58
Oct 18, 2016 08:24 PM
kents606
Sep 23, 2016 08:28 PM
brendanhayes15
Sep 1, 2016 11:24 PM
DuaLMaGz
Sep 1, 2016 06:18 PM
AEKnight
Aug 14, 2016 08:37 PM
