Transmission Failure
Old Dec 27, 2016 | 11:18 AM
SubwayVQ's Avatar
So since I've owned my car, it has always had a rough 2nd to 3rd shift. Once the car warmed up it would be good and shift fine. But now it's doing it in 1st gear. Even though the car is still hot, if I give it mild throttle it will shift out of 1st, hang for a bit and then slam into 2nd. I know the tranny is probably shot, but is there anything I can do to prolong the life? I don't have enough money to fix it or get a used one, so I'm stuck. It will shift fine under normal acceleration but if you get into it, it will do it. Not always though.
Old Dec 27, 2016 | 11:30 AM
SubwayVQ's Avatar
Also, the fluid level is good and it was flushed in the summer.
Old Dec 27, 2016 | 11:55 AM
mclasser's Avatar
Year/mileage?
Did you power flush it? Older transmissions sometimes fail after this is done.
Old Dec 27, 2016 | 12:11 PM
SubwayVQ's Avatar
2002 130k miles. The flush wasn't the issue because it only just started doing this. The flush happened way before that. I only said it so someone doesn't suggest changing the fluid.
Old Dec 27, 2016 | 02:15 PM
SubwayVQ's Avatar
So here's my plan now. Since I don't have enough money, I'm gonna drive the car how it is for a year or two until I get money. Then, I'm gonna buy a used transmission with low miles online. And then pay someone to swap it in. Hopefully the tranny makes it that long lol.
Old Dec 27, 2016 | 02:48 PM
Child_uv_KoRn's Avatar
Bad *** Newb
This is a common problem if there is a tranny issue. Replacing the solenoids can be a fix.
A power flush surely didn't help.
Old Dec 27, 2016 | 06:25 PM
SubwayVQ's Avatar
I'm just gonna buy a used one when the time comes. I read that the solenoid pack is a hit or miss. Plus that the pack doesn't control the 1-2 shifts?
Old Dec 28, 2016 | 06:15 AM
Derrick2k2SE's Avatar
http://car-part.com/
This site is great for locating used parts. A tranny will ship freight so don't worry about buying one from farther away.
Old Dec 28, 2016 | 03:35 PM
SubwayVQ's Avatar
Thanks, I just checked it out for a sec and there's quite a bit of them for about $2-300
Old Dec 28, 2016 | 04:22 PM
mclasser's Avatar
If you didn't have any problems before and they all began cropping up after the flush, then there's a high likelihood the flush is the culprit. Many shops refuse to flush after 100K since it can knock a bunch of gunk loose that can clog the tiny valves and passages in the tranny.
Try a bottle of Lubegard Red. Remove 10 oz of ATF and add the bottle of LG. It's one of the few non-snake oil additives out there actually mentioned in OEM TSB's.
And BTW, what ATF did the shop put in?
Old Dec 28, 2016 | 04:28 PM
SubwayVQ's Avatar
I have no clue, I bought the car after the fact. They showed me the receipt for it. When I buy my used tranny, I'll be sure to buy the proper ATF and give it to them to use.
Old Dec 28, 2016 | 04:33 PM
mclasser's Avatar
I'd try the $10 LG before springing for a new tranny lol
That's just me, though.
Old Dec 28, 2016 | 04:59 PM
SubwayVQ's Avatar
My last car had a tranny issue too. Tried changing the fluid and adding additives, but ultimately it started failing. I'm just gonna leave it how it is and get a different one. If it starts getting worse, I can throw in a bottle of that stuff.
Old Dec 28, 2016 | 08:41 PM
sanford7575's Avatar
Dude, LUCAS OIL TRANSFIX. Manual drain & fill with Valvoline Synthetic Dex/Merc high mileage 3 times, then on the 4th one add two bottles of Lucas and fill the remainder with the Valvoline. If this doesn't save it, it's time for a new tranny! Power flush = bad; drain and fill = good!
Old Dec 29, 2016 | 03:01 AM
kauaiwyatt's Avatar
I just replaced my trans at 139k. It had been acting up off & on for a year, but I was not using it the whole time. I tried new solenoids (did nothing) & a transgo hd2 kit. Don't waste your money trying the solenoids, IMO. I just got an ipt trans barely used for $850 swapped, & I love it.
Old Jan 6, 2017 | 02:44 AM
BronxSleeperMax187's Avatar
Here's what I would do.....save up 1500 bucks and get it rebuilt....that way you have a warranty and you know it has new parts. You can get a used one too but you won't know how much abuse it has already and what you are gonna get....also while you have it out might as well make it better by getting the shift kit put in....some say you don't need the tranny out to do the kit....wrong, do it right the first time....any codes for the tranny ? Sounds like the famous circuit malfunction code....tranny is gonna die so baby it and save...good luck.
Old Jan 6, 2017 | 09:13 AM
SubwayVQ's Avatar
No codes. I really would like a rebuild, but I want it to be as cheap as possible. That's why I wanted to go the used tranny route. But a rebuild will ultimately be the best route.
