Coolant Leak Fries ECU?
Old Apr 6, 2017 | 08:05 AM
  #41
Robert Baker's Avatar
Originally Posted by SubwayVQ
On a different note, I know my front motor mount is trashed because 1. I can see it, and 2. I get a clunk whenever I let off the gas and give it gas again on the highway. Also if I give gas too much from a dead stop, it will clunk too.
Anyway, I watched videos on replacing it, but was disappointed to find that they all said remove the radiator or cooling fans, which still requires to pull the upper hose. I hate coolant, but it looks like I can replace it without undoing anything. Hopefully I'll be able to do this job in the summer.
replacing motor mounts are way easier then that. 6 bolts and the whole thing drops in your lap. 2 bolts to the sub-frame, 2 bolts to the core support, and one bolt in each motor mount. I just replaced both of mine very very recently.
Old Apr 6, 2017 | 03:10 PM
  #42
maximatech12's Avatar
He/she is talking about the side mounts. You have to put a jack under the tranny where it attached to the engine right?
Old Apr 6, 2017 | 07:53 PM
  #43
DennisMik's Avatar
I'm pretty sure he is referring to the left side of the engine as he refers to the radiator fans.
Most people that have only worked on transverse mounted engines don't seem to know that the automotive industry has standardized left, right, front and rear as if the engine was mounted for rear wheel drive.
Old Apr 7, 2017 | 05:10 AM
  #44
I never heard that the lower mounts cause a clunk.
They discussed it was a
"passenger side engine mount clunk"
Old Apr 7, 2017 | 02:11 PM
  #45
DennisMik's Avatar
There is always a first time.
Old Jun 5, 2017 | 04:26 AM
  #46
Originally Posted by maximatech12
Is it possible this is from my deteriorating trans mount that looks cracked and broken? I'm seeing about an inch space at the bottom.
Would this cause a "bump"?
After buying the new mount I figured out the space is supposed to be there. It's the way it was designed!
