Should I gap these spark plugs?
Old Jan 14, 2017 | 09:03 PM
flames101sully's Avatar
I bought 6 of DENSO 4701 Iridium TT spark plugs due to postive reviews online (Crossing fingers these plugs are not awful). The gap for these are .040 and these cars say to gap at .044. I have heard you shouldn't gap iridium plugs, so will the current gap be good enough?
Here is the link to them https://www.amazon.com/Denso-IK16TT-.../dp/B00TPU8OT0
Old Jan 14, 2017 | 09:21 PM
maxiiiboy's Avatar
I would not bother.
My reasoning goes like this: Your gap of 0.040" is 0.1mm shorter then the recommended gap of 0.044" (1.01mm vs. 1.11mm). About 10%. We can't fully predict the impact of this slightly shorter gap, but I would reason that it might be equivalent to advancing the timing by a very small amount. (I assume that other parameters, e.g. spark size, are not significantly affected). All in all, not an issue and perhaps an advantage, IMHO.
Old Jan 15, 2017 | 07:04 AM
Derrick2k2SE's Avatar
Great plugs. you can't go wrong with them.
I wouldn't worry about gaping them at all. The iridiums will fire a nice hot spark with that gap. The gap opens as they wear anyway so I'd rather start a little under than over. The ones coming out will probably be over .55.
Old Jan 15, 2017 | 08:56 AM
Les7311's Avatar
I would not use them but instead "do it right the first time". Spend the extra so you don't have to regret something later. eBay is my best friend and I will find genuine OEM part there, to include the plugs I replaced on my '11 only two weeks back, and some I ordered yesterday for my tundra.
Old Jan 15, 2017 | 08:58 AM
SubwayVQ's Avatar
What?
Old Jan 15, 2017 | 09:15 AM
mclasser's Avatar
Old Jan 15, 2017 | 02:48 PM
Les7311's Avatar
Oh my. Here goes.
I would not gap the plugs. Better yet, just buy the specific plugs for your car, OEM PREFERRED. I have read on other forums where they used a recommended plug, then later had engine / gas mileage problems.
Spend the extra buck and get the OEM.
Hope this is better for a response.
Old Jan 15, 2017 | 02:52 PM
SubwayVQ's Avatar
Based on what Derrick has said, I don't think it's a concern. He knows his stuff and said that's a great plug. The car calls for Iridium so I think it's fine.
Old Jan 15, 2017 | 05:08 PM
Les7311's Avatar
Kewl beans.....
Old Jan 16, 2017 | 08:41 AM
Denso or NGK are the only plugs I'd ever put in the car.
I've not heard of anyone having problems with these plugs. Most of the problems are because people went cheap and put old school copper plugs in the car.
Old Jan 17, 2017 | 08:12 AM
Thanks guys, will check them to make sure they are all the same gap, but will not gap to 0.044. After I install them I'll let you know how it runs.
Old Feb 15, 2017 | 06:17 AM
New question. So I delayed changing plugs to get a little more out of the old ones. When I checked the gap for the new ones, they are all at 0.036. Now being 0.08 off of OEM spec, is this cause for worry?
