Grinding noise shifting between reverse and drive?
I just noticed my max is making a grinding noise switching between drive and reverse. Noise is pretty quiet (could easily be talked over) and pretty quick (maybe .25 second). To my novice ear it sounds like gears skipping a bit before engaging.
Other than the noise, transmission shifts nicely up and down, with a small squeak from 1st to 2nd when shifting under heavy load.
Is my transmission on its way to being FUBARed?
(2001 Max 190km, automatic)
Get yourself a stethoscope (http://www.harborfreight.com/mechani...ope-63296.html ), and listen on/around the transaxle while your helper shifts from D/R. You should be able to pinpoint it to a specific location.
Not necessarily. It could be one of your axles, or a bearing.
I inherited a stethoscope, but won't get to put it to use until the weekend. I'm wondering if a bad engine mount could be causing the noise, as the noise occurs only when shifting from R->D or D->R and not (D->N->D or R->N->R).
Interesting. Would never have conceived an axle causing a noise from shifting without moving the car - but I have essentially no knowledge of power transmission in cars.
Time to order the mounts and then wait for a nice day to remove and replace
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
