Brake servo
Old Apr 12, 2017 | 10:40 AM
maximatech12's Avatar
Brake servo
https://m.summitracing.com/parts/ado-15049288
What are the chance of this replacing the servo/A.C. pipe bracket?
Old Apr 12, 2017 | 07:33 PM
The servo pipe is 10mm and the a.c. pipe is 8mm
https://m.summitracing.com/parts/mfy-2032711
Old Apr 12, 2017 | 08:33 PM
Derrick2k2SE's Avatar
I wouldn't bother. Just slip a small length of hose over each one and zip-tie them.
They're not going anywhere.
Old Apr 13, 2017 | 09:31 AM
I guess ya could cut different size rubber hose lengthwise and slip it over the pipe to get the O.D. similar too or zip tie it.
I've seen zip ties with clips attached.
This hole I think 8mm.
These type zip ties are all through these Nissan cars. So good point!
Old Apr 13, 2017 | 09:56 AM
the larger hole is just a bit smaller than 10mm.
I believe this would be perfect if you could machine the larger hole out a bit.
Old Apr 13, 2017 | 04:33 PM
You're overthinking this. Any scrap hose will do. slit it lengthwise and if it's too big cut a strip out. Zip it to the nearest solid pipe or bracket.
Old Apr 13, 2017 | 07:49 PM
krismax's Avatar
Father of the 00 VI
Thanks for the idea, never thought of doing that
Old Apr 13, 2017 | 10:42 PM
No problem. I do that anytime I have to zip-tie a hard line to something. It gives it something to compress into so it doesn't get loose rattle around. I also do that anywhere I think a hose, pipe or harness is going to rub even if I don't secure it to anything else.
