flywheel
Old Jun 7, 2017 | 09:00 AM
uptownsamcv's Avatar
flywheel
I'm thinking it's time for a new flywheel and was wondering if anyone has ever had a similar issue... my 02 SE has that worn engine mount feeling when taking of from a stop in first but i have the energy suspension mount inserts installed... i had my brother check for engine movement when releasing the clutch in first and he said it barely moves... my car is at over 230,000 miles at the moment...
when i first put in the E.S. insets the car would take off nicely from a stop and now it has that heavy quick grab but sluggish roll off.... i put a new OEM clutch kit in at 175,000 miles...
Old Jun 7, 2017 | 06:41 PM
FanaticMadMax's Avatar
it likely that you may need a new flywheel the fact that you mention you have over 230k miles. Probably worn to beyond minimum spec, where the clutch wouldn't grab on the flywheel.
Old Jun 8, 2017 | 08:02 AM
Derrick2k2SE's Avatar
Does it feel like it's slipping?
Will it bark the tires on launch or on the 1-2 shift?
If it's not slipping it's probably something else.
Old Sep 23, 2017 | 09:08 AM
the main thing i notice is that when i take off from a dead stop the roll off response is real poor.. if i try to take off real fast from a dead stop it does feel like it has some slippage but not when i shift from 1st to 2nd, it will chirp the tires going from 1st to second...
