How do my spark plugs look?
Old Dec 19, 2017 | 01:11 PM
mclasser's Avatar
Finally got around to doing the plugs and leaking valve cover gaskets on my Infiniti. Here are a couple of the old plugs. I presume they are the original ones. What does the white crust mean?
Attached Thumbnails How do my spark plugs look?-img_20171219_142124940_hdr-copy.jpg
Old Dec 19, 2017 | 08:06 PM
crahel's Avatar
Net says running too Hot (lean) timing or fuel mixture too lean.
Old Dec 20, 2017 | 05:45 AM
Turbobink's Avatar
Perhaps it's the photo's perspective but the gap on those things looks pretty big.
Old Dec 20, 2017 | 06:58 AM
maximatech12's Avatar
What about soaking the tips in carb cleaner and scrubbing with a nylon toothbrush?
Old Dec 20, 2017 | 09:11 AM
Tarzan's Avatar
+1 for lean and huge gap.
Old Dec 20, 2017 | 09:12 AM
FanaticMadMax's Avatar
get new plugs and you are definitely burning too lean/too hot. How old are those plugs you had in the car, such as mileage you could been way over due on plugs change
Old Dec 20, 2017 | 07:21 PM
DennisMik's Avatar
You could do that to make the plugs look pretty, but it would nothing for the functionality. If you are going to do something to make the plugs work better, you need to dress the anode and electrode with a file and then re-gap.
Old Dec 20, 2017 | 10:55 PM
Derrick2k2SE's Avatar
I'd be willing to bet that gap is around .055 to .06
Probably original plugs.
Swap them with some NGK iridium plugs and be done with it. Assuming you're not having driveability issues at the moment.
You can always pull the front ones in a few miles and inspect them then. If it's a tuning issue the crust will return. It can be dealt with then.
kevin11
26
Sep 9, 2007 10:28 AM
blinelaxd27
Jun 26, 2005 07:20 PM
Colossus
Jul 25, 2004 03:06 AM
Colossus
Jul 23, 2004 01:08 PM
Lo-Tse
Sep 1, 2002 10:32 AM
