Power steering pump pressure hose
Old 12-28-2017, 04:07 PM
tnvmax's Avatar
Hey people can anyone tell me if gen 4 hoses are the same as the gen 5? Wrecking yards only seem to have gen 4 cars in them around me.
tnvmax is offline
Old 12-28-2017, 11:20 PM
Derrick2k2SE's Avatar
I can't tell you if the 4th gen will fit but it is a very common problem on all the 5th gen cars. A junk yard hose may not be the best choice unless it looks like it's been replaced recently.
I took mine to a local place that makes and repairs hydraulic lines. They used the fittings and built a new line for a lot cheaper than a new one. Not as cheap as a junkyard part but essentially a brand new line.
Derrick2k2SE is offline
Old 12-29-2017, 06:48 AM
CS_AR's Avatar
This is basically the hydraulic hose replacement repair process for heavy equipment with super expensive lines.
I have read a lot of complaints about aftermarket pressure side hoses not allowing enough fluid to pass through the banjo bolt fittings. As a result, the owners experience power steering pump whine. So I would get my OEM hose repaired instead using an aftermarket. That is if I could not get a new OEM hose.
CS_AR is offline
Old 01-03-2018, 05:42 PM
TSelanne's Avatar
What year is your car?
4th gens and 5.0 gens are the same AFAIK.
5.5 gens have a different harness connector up top. You can take this connector off and put a 4th or 5.0 connector on, and you'll be good to go.
So if you currently have a 2000 or 2001, you can find anywhere from 1995-2003 and make it work.
TSelanne is offline
FenderGuy
08-17-2012 12:44 PM
nishfish871
09-07-2011 08:17 PM
MWM
08-17-2010 08:17 PM
Quick Reply: Power steering pump pressure hose
