00 Maxima idel problomes please help!
I just got a 2000 Maxima and when I got the car it would only start with when you pressed the gas pedal all the way to the floor and it idels like crazy up and down until it warms up then when warm it stays up at like 3 grand and when you rev the car it cuts out at 3500 I had a scan tool on it and it read. - ignition control switch - and - ETC motor power - I was told it could be tps I adjusted it and it kinda helped but still idels like crazy. Don't know what to do any help would be appreciated!! thanks!
Well i scaned it with the live data tool and looked for any vacume leaks I don't think that's it. My tps reads 7.1% at idel or at what it idels at which is 2500. Still tho when you got the gas pedal it revs up to 3 and cut a out and does that over and over even just barely touching the gas pedal will a stuck IACV cause this? Thanks!
Check the resistance of the IACV stepper motor windings. They should be 22 ohms and all 4 windings should be within an ohm or two of each other.
For directions on how to do this, see pages 502 & 506 in the service manual. Link below.
http://boredmder.com/FSMs/Nissan/Maxima/2000.5/EC.pdf
Hey guys. Good news I did replace the tps today and it fixed my extremely high idle. But do still have a little bit of a high rpm problome it now stays about 1200 1300 still a little high. And car still buckles badly under a certain spot in the gas pedal when just slightly pushing it.
I doubt if it is a bad ignition coil. A bad ignition coil would create a "dead" cylinder which would make the engine miss and the idle would be slower.
The engine cutting out at 3500 rpm sounds like a MAF, but I have not heard of a MAF causing high idle.
In fact you gotta pick up a feeler gauge. Then shim the accelerator cable hook-up against the stopper as you adjust it with the gauge.
Its a real dreadful job.
Clip the volt meter on the lower top pins 4 & 5 and twist the TPS until no continuity.
Another route is just take it over to Nissan and pay them to do it.
Theyll then re-set idle air volume & closed position memory!
With this car the TB has some computer re-set involved.
Check out Nissan Data Scan 2. Online if you want to complete this job yourself but any time you remove the IACV or TPS there is some reprogramming involved.
May have to try the dealer. Really hope it doesn't come down to that do you think possibly could be a bad crank position sensor? Because it has a real bad sulfer gas smell when its struggling to start and and stumbles when you taking off and shifting
#1 a feeler gauge
#2 multi-meter
Check the procedure in the EC section.
Then pull CPS(POS) & (REF) & CAM check for cracks or anything unusual.
Check the oil for a fuel smell or have a small amount sent off to BlackStone for analysis. If it smells like gas then the injector valve may be leaking after the car shuts off. Then the gas puddles up on the piston
My car stumbles as well at start up after replacing everything your concerned about
It runs great though once its up and running
I have the 2001 and im pretty sure there is only 1 Camshaft sensor
MaxiMan1997
Jan 2, 2018 12:42 PM
iceberg8389
22
Jul 11, 2016 05:46 PM
4thgradedropout
22
Jan 18, 2007 02:24 PM
95turbo gxe
Oct 14, 2006 05:44 PM
