Intake Leak?
Old Feb 23, 2018 | 04:12 PM
maximatech12's Avatar
Intake Leak?
I cant figure out if this noise is normal but im considering pulling the intake again this year sometime and/or replacing parts.
https://youtu.be/cpAfInlPk90
Old Mar 9, 2018 | 05:01 AM
Is it possible the intake manifold collector is allowing air in somehow?
Is it common for these to crack or leak after so many years?
I did pull the TB and re-sealed that and the egr block off plate and still this hissing noise. I grabbed a mechanics stethescope from HF a while back and thought it was the egr block off plate seal but i cant seam to pin point this that way.
Old Mar 9, 2018 | 07:52 AM
Derrick2k2SE's Avatar
Use the brake parts cleaner trick. If you spray it on an intake leak you'll notice a change in the RPM right away.
Old Mar 9, 2018 | 08:49 AM
What i did ​​​​Was
Removed the​​​​​​ intake piece that attaches to the radiator support
Then​​​​​​ started the engine and covered the hole before the filter and the car didnt stall.
Also tried starting the car without the air cleaner box and car wouldnt start.
Old Mar 9, 2018 | 01:47 PM
Thanks i checked again and im finding the manifold to be pretty well sealed up.
edwardh1
37
Sep 12, 2015 07:10 PM
BigLou93SE
Dec 15, 2005 12:16 PM
reMaxxxK
Oct 3, 2005 06:47 PM
nycspudz03
Feb 2, 2005 07:38 PM
[maxi-overdose]
May 21, 2002 12:43 PM
