p0304/P0300 and a rod knock?!
Old Mar 28, 2018 | 10:41 PM
SAsMaxima's Avatar
Long Story Short
Driving down the freeway, SES Light flashed, slight loss of power, vibration, and knock! Pulled over, checked code and p0304. Towed car home -_-
Looked around engine bay no visible issues, all fluids looked fine. Ran engine for 1min to get the vid.
Plan of action:
  1. check spark plugs - carbon deposit on plugs in cylinder 2,4,6. Replaced all 6 plugs
  2. coils - check resistance on all coils, all within specs. Replaced cylinder 4 coil with a new hitachi i had laying around.
  3. check injectors
  4. check MAF
  5. compression test
After conducting 1,2 cleared code, and now have a p0300. The sound the car has going on has me thinking it may be a rod knock or piston knock. Ohhh the fear of saying goodnight
Old Mar 28, 2018 | 11:44 PM
BronxSleeperMax187's Avatar
SO you swapped the #4 coil and still the same sound but only one code now ? Try another coil and return it if its still no good at autozone.....don't tell them you used it lol
Old Mar 29, 2018 | 09:16 AM
SAsMaxima's Avatar
Yeah pretty much, had only p0304, now only p0300. Will conduct the other test later on tonight, and report back.
Old Mar 29, 2018 | 01:30 PM
Jbice1995's Avatar
Hey, I had the same thing happen to my 03 at the end of last year. Casually driving home, all of a sudden CEL is flashing and the car has a nasty misfire and sounds likes its knocking from hell.
Wanted to tow the car home, ended up saying **** it and drive it home 45 miles anyway with the misfire. Pulled codes and got p0304 and p0300. Oil in spark plug boots and one plug was really fouled out.
You can confirm that the coil pack itself is bad by swapping the presumed bad coil with another coil pack from a different cylinder, clearing the codes and restarting the car this is obviously easier on the front of the engine than the back. I was able to do this by switching 4 with 6, and the code followed as well. Ordered a brand new OEM Hitachi coil pack, installed and the car ran golden as it ever has.
But yeah, I for sure thought the car was toast. The misfire was so bad and the engine was shaking so violently I thought for sure the noise was rod knock, but here I am still driving it daily and she is quiet as can be since the new coil pack and new plugs.
Old Mar 29, 2018 | 07:42 PM
nestorlugo's Avatar
It's toasted man sry
Old Apr 6, 2018 | 08:55 AM
JosueblondeOG's Avatar
What you mean as in done for?
Originally Posted by nestorlugo
it's toasted man sry
floppy_disk
Oct 29, 2015 09:58 AM
heresjohnny151
Mar 21, 2015 05:40 AM
Saddles
Apr 1, 2012 09:11 PM
mattj10
Oct 27, 2011 07:08 AM
DOM
Aug 28, 2011 09:07 PM
