bulbs
bulbs
i understood that the foglights for the 2k max is h-3 55 watts
but i keep seeing superwhite bulbs h-3 100 watt, can i use those instead?
also, wut bulb fits the side markers?
i see all these numbers and volt/watt numbers, dont know which one
Re: bulbs
if you get 100W overwatt bulbs you will need a new wiring harness
make sure the package does not say 55W but looks like 100W..then the bulbs are OK
side markers are 194s
Re: bulbs
Side markers are 194 bulbs
Those bulbs that say they use the same wattage as stock but give off a higher wattage out put don't last very long. Stay away from them. I can tell you from experience with my privious car that you'll get addicted to the look of brigher bulbs and keep buying them even though there life is short. Stick with HIGH QUALITY BULBS with the same wattage as your stock bulbs.
can u give me some compnay names?
do i necessarily hav to order this stuff?
or is it all available in some retail store??
wut bulbs u think i should use (any ex)?
Re: Re: bulbs
Originally posted by Greg's2kGLE
Usually the wattage on aftermarket bulbs is the equivalent output of the given wattage. Say it says 85 watts, (stock is 55) so it will put out as much light as an 85 watt bulb, but not actually being 85 watts so it won't fry your harness. Sometimes this is the case.
Re: Re: Re: bulbs
Originally posted by HondaKilLR
How do you get to the Fog lights in the first place? Do you have to remove the whole under-wheel fender? Have the bulbs to replace and can't quite figure it out. PLease advise. Thx
knight_yyz
Nov 1, 2015 01:34 PM
