No response when in drive or reverse?
Old Apr 19, 2018 | 12:42 PM
Kjizzle's Avatar
I have a 2003 3.5 maxima , car randomly had no pedal response when I pushed it to the floor I coasted to a stop idles fine, neutral revs up normal, drive and reverse I get nothing when pushing the gas.. all the forums say different things varying from ( alternator, vacuum leak, MAF, bad ground, knock sensor,) I’m not trying to spend a crap ton at a mechanic if it’s an easy fix but the alternator job is tough without a lift or jack or jack stands. So just wondering if it’s a simple fix or not. Has new plugs and ignition packs. Check engine light was on dude to 02 sensor/ bank 2 catalyst. And converters cost a lot so that’s why haven’t got that done yet. Or is that the issue?
Old Apr 19, 2018 | 07:47 PM
nestorlugo's Avatar
Trans fluid?
Old Jul 21, 2025 | 08:01 PM
1974's Avatar
I have a 2016 that is doing the exact same thing. Did you ever find out what is going on?
Old Jul 22, 2025 | 03:55 PM
uptownsamcv's Avatar
if the engine isn't revving when you tap the gas check the rubber stopper that the pedal makes contact with. it's the rubber green piece in the pic. it's the same as the one you would normally use for the brake switch but it's green. Nissan doesn't sell the green one but the black one for the brake switch works fine..
Old Jul 29, 2025 | 07:10 AM
CMax03's Avatar
Hard to understand what your problem is with no periods in your explanation. Sounds like it Rev's to your throttle input only in Neutral? Is that correct? Check the stop button of the your throttle first! Then if it's there (The green plastic stop) i would say you have a tranny issue.
Letmrfixit
Jun 23, 2022 06:43 PM
supa
18
Feb 12, 2013 06:51 AM
speed racer
May 3, 2011 02:57 PM
nymax99se
18
Aug 30, 2009 12:07 AM
rguida
Dec 1, 2002 06:58 AM
