Cant figure out whats wrong , tricky problem !!
Old Apr 29, 2018 | 11:51 AM
dylannn3's Avatar
I have a 2000 nissan maxima it accelrates really poorly from 40-100 its sluggish and it sounds really horrible like its surging thats the best way i can explain it , i do have a CEL for a massive evap leak idk if that could be the problem , the car sounds horrible when accerlating and i really need help pin pointing the possible soolutions to this problem
Old Apr 29, 2018 | 02:16 PM
Theslaking's Avatar
The evap solenoid/vent valve could be stuck open or broken.
Old Apr 29, 2018 | 03:21 PM
MadMax SE's Avatar
what do you mean by it sounds horrible? Ticking, Exaust noise, marbles in a can noise, knocking?
Old Apr 29, 2018 | 03:38 PM
dylannn3's Avatar
the noise is coming from the engine , when you accelerate it’s sounds like it’s clogged up or struggling to pick up speed but it’s not struggling to pick up speed it just sounds horrible
Old Apr 29, 2018 | 06:30 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Check codes to make sure knock sensor isn't on there.
Replace Y pipe with aftermarket (no cats). If it's high miles (and I'm sure it wasn't maintained), then precats are probably clogged. Gut the rear cat, too.
If it seems fine at low rpms, then hits a wall at high rpm, then that's pretty much a guarantee. I don't think maf would cause what you're describing, since you said it sounds bad.
cfiggs
27
Jul 9, 2009 10:07 PM
mastercater7
21
Nov 7, 2006 05:51 AM
loverholic
Nov 17, 2005 01:33 PM
tcrow31
36
Nov 13, 2005 09:54 AM
ILOVEMYSE
24
Oct 25, 2003 08:12 AM
