How many bolts are on the bank 1 pre cat vq35?
Old May 24, 2018 | 09:08 PM
maxinout93's Avatar
Im attempting to remove my bank one pre cat and gut it like i did the bank 2 pre cat near the radiator. It was replaced with a new one about 100K miles ago and im suspecting its semi clogging again as the car has gotten a tad slower and the floor gets hott sometimes. Being that it was replaced with new bolts and screws they are not too difficult to remove. From the bottom I see three at the y-pipe and i can remove those. Now this is where the question comes in is at the top. Do i need to remove the rear exhaust manifold? kinda difficult as i dont have alot of room. I see 2 bolts at the top of pre cat that i did remove, are there anymore? I put the bolts back in because i was running out of time and it was getting dark.
Old May 25, 2018 | 06:42 AM
Prophecy99's Avatar
all done!
rear is harder material, more dense, be more patient, 25-30 mins time, front (90 deg elbow) is easy 5 - 10 mins time.
16" spade bit for wood is what i used, and i recommend corded drill, because it would prolly eat at least 3-4 batteries on cordless drill
tools - drill, 16" long x 1" wide spade bit, and chisel, and hammer and vice grip or something for securing the pieces while doing the work,
hopefully that helps
Old May 25, 2018 | 04:50 PM
freezer's Avatar
I would recommend removing the rear engine mount bracket and then removing the manifold.
I have almost every variation of 14mm and I needed most. A flex-head ratchet and an offset box wrench to get the manifold off. Having a good selection of extensions (preferably the ones that are tapered to allow slight misalignment) are nice to get that rear motor mount bracket out.
Mine had only been in for a year and I think I put anti-sieze on everything so they came out favorably. Your mileage may vary
Old May 26, 2018 | 01:06 PM
RA030726's Avatar
I'm nutty for Nissans
Remove the intake plenum.
Remove the heatshield.
Now you can access the top 2 fastners holding the cat to manifold.
Old Jun 3, 2018 | 07:13 AM
maxinout93's Avatar
Yeah i can access those two and remove them, But from the top of the engine, I cant see where the other 2 bolts are. If i can find them from the top then i can remove the pre cat. It would save me some money as one person quoted me $400 to remove and replace it saying it would take 5 hours.
Old Jun 3, 2018 | 09:56 AM
RA030726's Avatar
From the bottom there are two nuts where the cat meets the manifold. A few extensions will help to reach them.
Old Jun 3, 2018 | 09:35 PM
maxinout93's Avatar
Gotcha thanks alot
maxinout93
18
May 27, 2016 12:40 PM
sean16921
Mar 19, 2013 11:03 AM
rubicon03
Mar 31, 2012 09:06 AM
1991Maxima1991
93
Sep 5, 2011 10:59 AM
nardo'89SE
Apr 20, 2002 09:48 PM
