Battery Light & Brake light intermittently coming on for split second and going off
Old May 25, 2018 | 09:11 AM
ktr944's Avatar
Verify recently, my car started to show a symptom where Battery Light & Brake light intermittently coming on for split second and going off. I also see the car to be running bit rough specially pushing pedal on gas (i see high RPM at low speeds).
Really appreciate if anyone can point to what could be going wrong here ? Is thing something serious ?
Old May 25, 2018 | 09:20 AM
TallTom's Avatar
I think your alternator is on it's way out. I'm pretty sure those are the two main symptoms. Do a search on here for alternator symptoms.
Old May 25, 2018 | 11:35 AM
maxiiiboy's Avatar
Yes, as stated above: your alternator is about to fail, or you have a loose connection somewhere between the alternator and the battery.
Old May 25, 2018 | 08:01 PM
Les7311's Avatar
^^^^^ x3
Old Jun 19, 2018 | 03:49 PM
maxinout93's Avatar
alternator is def about to take a dump sooner than later.
Old Jun 29, 2018 | 08:06 PM
maxinout93's Avatar
car currently doing this now out of the blue the battery and brake light came on today, shortly after taking it to autozone for a battery check which they said it was low on cranking amps. It died on the freeway so i coasted to a stop. Not sure if its a battery or alternator problem it seems like everything was fine until i turned on the a/c and it shut down until i came to a stop. Didnt have enough juice to start back up so i grabbed a jump starter and she started up. But still at a stop the batt and brake light come on. Luckily i wasnt far from home. Hoping this might be the source of my a/c problems.
blacck_dragon
46
Feb 18, 2016 03:16 PM
BiZzL3
64
Oct 10, 2014 07:38 PM
95maximase
Jul 1, 2006 09:13 AM
talisman311
Jan 4, 2006 11:08 PM
lhercules
Jul 12, 2005 08:14 AM
