Nth TEENth non LSD to LSD 4AT conversion thread?
Old Jul 13, 2018 | 11:51 AM
cdoublejj's Avatar
i though the lockers had numbers stamped/molded in to the casing to designate their difference form non locker. or so logic would dictate in my mind.
If only i remember what threads all this info was scattered in. is it RE4F04V or an "A" with different markers/numbers? pretty sure you can take an infinity locker and "drop it" in to the 5th gen max 00-01 and or 02-03
I also go to wondering if the TCU or ECU in a non locker would like dealing with a locker trans? i thought all the autos LSD (VLSD) or not have TCS?
i'm sure it's the 1 millionth question on this subject but, it doesn't always come up in designated threads and or old links are broken.
Old Jul 13, 2018 | 02:28 PM
RA030726's Avatar
I'm nutty for Nissans
The VLSD has a larger oil seal on the left side. Very easy to spot. It works on it's own meaning it's not electricity controlled.
TCS might be part of the ABS, not just the TCU. The 99 TCS was only available with ABS and auto trans. I don't have the specs for 00-01 but I'd assume it is the same.
Old Jul 14, 2018 | 10:42 AM
cdoublejj's Avatar
i should have stated i'm trying to not get ripped on at the junk yard or ebay. if i'm not mistaken the/a VIN decoder may be able to help tell if it's a locker.
i've curious if the VLSD acts like an LSD when you jack it up and turn the wheels since it needs hydro-static pressure / pressure / friction to kick in.
Old Jul 14, 2018 | 07:01 PM
RA030726's Avatar
You can go by the VIN if the tag is still there. My trans came from a local salvage yard with no VIN tag.
Even if a car came stock with a VLSD, it is possible it was swapped out at some point with a non locking. You really should visually verify. Again the big left seal is easy to spot. Also there is no obstruction when looking through the holes where the drive shafts insert.
You can check function as per the FSM.
Old Dec 26, 2018 | 10:39 AM
cdoublejj's Avatar
Is that a bigger oil seal ID or OD? i'd hat to measure the seal ID only for that be the same? also isn't there code or something on the case?
Old Dec 27, 2018 | 08:04 AM
RA030726's Avatar
The OD is larger.
I can't tell you if the numbers on the case indicate the trans specs.
Old Dec 10, 2020 | 10:00 AM
cdoublejj's Avatar
i haven't found any vin decoders that say locking vs non locking???
skweaky
May 26, 2011 02:32 AM
eclypsecl
Jan 8, 2007 04:19 PM
madmax96
Jan 7, 2005 08:32 PM
ChristheNite
Oct 7, 2004 03:17 PM
69CHARGER_RT
Sep 27, 2004 01:11 PM
