Cluster LEDs - 2018
Old Sep 22, 2018 | 10:56 AM
freezer's Avatar
Cluster LEDs - 2018
Just wanting to start a new thread on cluster LED options. Currently, I have superbrightled plug and play warm white 3 LED installed. I like the white color they produce in my SE cluster but don't love the hot spotting.
The hot spots are not as noticable at night, but at dusk they really stand out. I picked up some lighthouse LED flat top cool white to try out but they are quite blue in the cluster and didn't reduce the hotspots.
Cluster LEDs - 2018-20180921_131518-1612x1209.jpg In addition, they are a nuisance to install requiring resistors and custom fabrication to use the 74 base.
I found these vleds VLED 74 6 LEDand wondering if anyone had tried these out? I'd prefer a warmer color temp than they offer though.
Old Sep 22, 2018 | 04:26 PM
User1's Avatar
Thanks for posting this. This was going to be my next task after the swap. My cluster is entirely too dim. I may even have a bulb out, not sure. I've had the car since July and have yet to drive it even just around the block. Is the cluster removal pretty intuitive? Any tricks to disassembly? I hate asking questions before I assess an issue for myself as I'm usually able to figure most things out, but I'm starting off with zero knowledge about stock cluster removal and this will be my first.
Old Oct 5, 2018 | 08:44 AM
cdoublejj's Avatar
I guess you'd need to make a diffuser to help with the hot spots. or maybe they make higher end LEDs with better diffusion, other wise i'd probably just run bulbs for that very reason.
Old Oct 5, 2018 | 04:05 PM
Those look nice but wow, at $6 per bulb I hope they really do eliminate the hot spots!
I just purchased some 3 LED pure white bulbs from eBay. Will install and check back in tomorrow. They are a bit cheaper at $6 per pair.
Old Oct 5, 2018 | 06:22 PM
NotYou's Avatar
https://www.superbrightleds.com/cat/...ed,121,39,360:
The 5mm, 360 degree led's in the above link are the only ones I know that dont hot spot. They work great in my HVAC.
Obviously a little soldering and a resistor is needed...plus this for the dash:
http://www.autolumination.com/wiring...-bulb-base.htm
Old Oct 6, 2018 | 11:44 AM
Checking back in. Still have some minor hot spots. Will likely be more apparent at night but not as bad as before.
First picture shows style of old bulbs, second pic shows style of new bulbs and third pic shows the new bulbs installed.
EDIT: Link to the bulbs purchased.
https://rover.ebay.com/rover/0/0/0?m...2F253064197160
Attached Thumbnails Cluster LEDs - 2018-d8442e81-0553-4c93-8eab-b949b49fc18f.jpeg   Cluster LEDs - 2018-e08e18c2-1b9a-4bcd-a591-a046484f4079.jpeg   Cluster LEDs - 2018-16883957-5df2-494e-9d53-4decef9f13ce.jpeg
Old Oct 7, 2018 | 12:21 PM
User1's Avatar
Thank you for this info! Definitely on my list!
Old Oct 7, 2018 | 05:13 PM
MaxinO2's Avatar
Interesting. I have super-bright led's blue color installed without any hotspots.
It's been a while since the install, but I do believe there are 3 leds per bulb. Maybe I find the exact bulb type that I ordered if that would help you.
Can you turn/insert the bulbs 180 deg to see if the light is dispersed differently?
Old Oct 8, 2018 | 05:41 AM
Prophecy99's Avatar
is the cluster hard to take out and switch bulbs? my MPH side has been out (of and on randomly) for couple years and i got LED bulbs to replace...i can post results if I can do the cluster myself =)
Old Oct 8, 2018 | 05:46 AM
Not sure. Would have to try one of these days.
Not hard at all! Just need a 4-6” Philips head screwdriver. I remove the lower dash panel below the steering wheel, the column trims and then the gauge cluster trim and cluster.
Old Oct 8, 2018 | 06:55 AM
freezer's Avatar
Checking back in. Still have some minor hot spots. Will likely be more apparent at night but not as bad as before. Link to the bulbs purchased.
These bulbs look pretty similar to the ones I got from superbrightleds, and pretty similar results.
Even though I want a plug and play solution, those bases might make the process tolerable. My HVAC hotspotting is currently worse than the dash, but I don't spend as much time looking at it.
Old Oct 8, 2018 | 12:11 PM
Prophecy99's Avatar
Thanks dude ! gonna try this soon dosent sound too bad, and i will post results, i got plug and play bulbs superbrightleds.
Old Oct 18, 2018 | 06:12 AM
Prophecy99's Avatar
cant find my bulbs now.... sigh... my shifter light is out too, any one know that size?
Old Oct 18, 2018 | 08:17 AM
Prophecy99's Avatar
^It differs from 2000/2001 to 2002/2003. The 2000/2001 is a #194, which is a T10 wedge size.
The 2002/2003 is a T5 size, or #74, which is the same as the Gauge cluster, key ring, over-ashtray light, and glovebox light.
great member, found this searching for shifter light.
Old Oct 19, 2018 | 03:23 AM
Theslaking's Avatar
What's a shifter light? I could have the cluster out in about 3 minutes. It's really easy. I also have super bright led's throughout my car with zero hotspoting. I bought them within the last year so maybe they have? newer versions that work better.
Old Oct 19, 2018 | 04:17 AM
danmack34's Avatar
thanks ChrisMan and freezer! just got a maxima daily again to add to my M3 and Accord and first post back I get some great info from one of the OG's
Old Oct 19, 2018 | 04:18 AM
Prophecy99's Avatar
where did you buy them ? and sounds good w taking the dash apart ! i always thought it was a head ache, but yea most interior stuff isnt all that bad
Old Oct 19, 2018 | 04:19 AM
Prophecy99's Avatar
pics ! or no proof =)
Old Oct 19, 2018 | 05:22 AM
danmack34's Avatar
Most know for making the badge less grills back in 2007-8 ish after seeing ERTY67’s (still hang out with Uncle Ed to this day and DJ420 , they’re the homies still)
Old Oct 19, 2018 | 05:26 AM
danmack34's Avatar
2003 titanium edition with 88k on it fell into my lap at work , quarters are PERFFFECT and just had it wetsanded , cut and buffed. so far EVERRRY bulb replaced LED besides the cluster which I ordered the leds chrisman /OP said to to reduce hot spots. next is putting on the track editions I had on the Original maxima I had (I have 3 sets of track editions!) , coilovers and install my DDIN I kept from my maxima lol love it just got the bose harness in BUT maybe one of you will know the DDIN dash kit I got isn't titanium! its a grey color. where can I get the correct one
Old Oct 19, 2018 | 05:30 AM
danmack34's Avatar
Oh and here’s said M3 , also since I’ve veen gone I started broke. www.brokeAllDay.com and host events 😎 I’ll be posting a lot more now and hopefully contributing back as I used to. But this post helped a lot because I was concerned after seeing the terrible lighting stock after replacing all the interior leds
Old Oct 19, 2018 | 05:55 AM
Maaaan welcome back. I tried buying a grill off you a while back but no reply so ended up making my own lol I have one of your originals off my boy’s car but it needs some touching up.
Attached Thumbnails Cluster LEDs - 2018-0063de52-632a-4ad9-8cb0-27f580eb20bd.jpeg
Old Oct 19, 2018 | 07:50 AM
TallTom's Avatar
I think he is referring to the small bulb above the area of the ash tray where the light shines around the shifter and central console.
Old Oct 19, 2018 | 08:39 AM
Prophecy99's Avatar
very nice man ! that thing is freaking mint, body and mileage! wow especially NE car too! wow, sweet color too. i made a badgeless grille for mine ! =) i figure give or take 80 hours from fab to paint. before there was an ebay one arghh!. lol
what coils are u thinking? and sorry i have no idea on the dash kit stuff. but welcome, good
nope ! i was referering to the back light at the actual shifter that illuminates PRD321
Old Oct 25, 2018 | 04:14 AM
danmack34's Avatar
so I got "white" leds and it looks blue -_- I ordered new actual white leds and im gonna try again. the seller claims white .. nah blue
Old Oct 25, 2018 | 06:10 AM
freezer's Avatar
If you have an SE cluster you need to buy warm white ( yellowish) if you want the cluster to appear white and not blue.
Old Oct 25, 2018 | 02:21 PM
Theslaking's Avatar
SEM color match paint
​​​​​​​I was making a joke about not having a manual.
Old Oct 27, 2018 | 08:02 PM
The_Fixer's Avatar
5.5 gen clusters will always look blue because of the tint on the cluster face
Old Nov 6, 2018 | 04:02 AM
danmack34's Avatar
Bt
btw thank you all for the info! I’m gonna try warm white to get they white color I’m loooing for but for now the light is even and bright vs the old bulbs !
Old Nov 6, 2018 | 05:17 AM
Prophecy99's Avatar
looks great man ! i cant find the bulbs I got for this, so i am gonna agree with you and get warm whtie to avoid the blue look as much as possible.
Old Nov 9, 2018 | 05:11 AM
Prophecy99's Avatar
are the oem bulbs in the guage LED? or incandescent? i cant figure out why the past 4 years the mph side has been out for 80% of the time, and then turns on when it wants on a rare ocassion, today driving to work, and it turned on in middle of drive, but then stays off for days at a time.
my key ring is out, shifter light, and mph light, and come to think of it probably glove box.
Old Nov 9, 2018 | 04:41 PM
freezer's Avatar
The 4 illumination lamps are incandescent, high beam indicator and turn signals too IIRC. Everything else in the cluster is LED for MY 2002-2003
Old Nov 14, 2018 | 07:57 AM
Prophecy99's Avatar
thanks Freezer, i have no idea then why my MPH gauge turns off an on when it wants too , it was on this morning but not on last night.
Old Nov 20, 2018 | 01:12 PM
pastaben's Avatar
Can you just pull out the old bulbs and plug the LED bulbs in, or do you need resistors and other parts?
ac max 92
Jul 17, 2015 06:37 PM
a33_ridah
Sep 27, 2014 02:31 PM
Jwad00
Feb 22, 2007 06:32 PM
JetBlackMax83
Aug 5, 2004 09:42 AM
