Power Steering Pump
Old Mar 6, 2019 | 08:21 PM
Leo Julian's Avatar
Power Steering Pump
My power steering pump is leaking. What is the best procedure to remove it. I saw some video on YOUTUBE. I am having trouble removing the pump pulley. Some info states to put a pry bar-screw driver thru
pulley opening . But I have not had success with that due to fact that I cannot get the pry bar to stabilize behind the pulley.
It seems best to remove the pulley to gain access to the mounting bolts. Please correct me if I am wrong.
Old Mar 6, 2019 | 09:02 PM
FanaticMadMax's Avatar
Oy I know the difficulty of the pump there a bolt behind the pump which you literally have to get under the car and look and you have to loosen that before you start
loosening the bracket tensioner because I had trouble and bent the tensioner bolt which I didn’t know about the bolt back of the pump body
Old Mar 6, 2019 | 09:08 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Are you sure it's not the return hose at the connection or HP hose (leaking under the foam)? It's pretty rare for the pump to go bad.
Old Mar 8, 2019 | 10:00 AM
krismax's Avatar
Father of the 00 VI
Do not remove the pulley you don't have to.
This is not worth doing yourself if your not experience in this type of thing .You will regret working on it to save a few bucks.
The two above are right it may not be leaking. And you have to go from the bottom to get the long bolt.
rbarnes
Dec 31, 2015 06:29 PM
maxkid123
Nov 22, 2008 07:42 PM
Kof
Jan 11, 2008 05:47 PM
ivolley
Jan 21, 2004 01:02 PM
MichaelAE
Jul 6, 2002 08:19 PM
