Engine Harness Only Has 3 Injectors and Coils
Old Mar 14, 2019 | 07:43 PM
Violator's Avatar
Is this a 2 piece harness? Ive only got 3 injectors connectors and 3 coils does the other half plug into the main harness? I wanted to finally start my engine swap up tonight and I run into this bs
Old Mar 14, 2019 | 08:19 PM
User1's Avatar
There are three connectors exiting the main harness at the plastic enclosure that bolts to the timing cover. They are larger, 6 pin connectors. One is dark blue and requires a sub harness for the Bank 1 cam sensor. The second two are dark green and accepts the Bank 1 coil and injector sub harness.
Edit: exiting
Edit: Christ, sorry, Violator, there are 3 big connectors. I'm sure you've seen them. 2 green, for coil and injector, 1 blue for cam sensor. Sorry, it's been a month and a half since I had seen them. You get it.
Old Mar 14, 2019 | 09:15 PM
krismax's Avatar
Father of the 00 VI
Originally Posted by User1
There are two connectors on the exiting the main harness at the plastic main harness enclosure that bolts to the timing cover. They are larger, 6 pin connectors. One is dark blue and requires a sub harness for the Bank 1 cam sensor. The second is dark green and accepts the Bank 1 coil and injector sub harness.
Edit: exiting
Where is your thread???!!
Old Mar 14, 2019 | 09:19 PM
User1's Avatar
I removed everything. I'm just here to see Violator through.
Old Mar 14, 2019 | 09:26 PM
User1's Avatar
Or not... It appears that higher powers have decided to re-publish and lock previously deleted content. Not my site. What can you do. Anyway, enjoy.
Old Mar 14, 2019 | 10:00 PM
Slamrod's Avatar
LOL imagine having a thread so dope that the mods literally wont let you leave. You might as well just stay. Dont forget, you’re here forever
Old Mar 14, 2019 | 10:02 PM
krismax's Avatar
Father of the 00 VI
I'am confused, why would he delete everything? Why put so much effort into something to get rid of it?
Old Mar 14, 2019 | 10:07 PM
User1's Avatar
I don't know any of them. No one has contacted me. Maybe the Wiz?
Old Mar 15, 2019 | 07:54 AM
Violator's Avatar
Actually i asked if he could reopen it so I could write a CPL things down I hadn't. He said to make sure I saved it like it wasn't gonna stay open. Why did you delete it all in the first place?
I'll go up to the yard and pull the sub harnesses tomorrow or sunday. It's always something
Kretzmech
Feb 19, 2016 10:55 AM
edlab03
May 7, 2010 09:47 PM
mooze
Aug 5, 2007 10:13 AM
michaelnyden
May 22, 2006 07:36 PM
92 Max
Jan 26, 2006 04:24 PM
