When Do You Recommend Rod Bearing Replacement?
Old May 21, 2019 | 07:56 AM
Cephyr13's Avatar
2001 Maxima 5sp w/ 202k
When do you guys recommend replacing the rod bearings?
I don't have a reason to change them, really, other than my harmonic balancer is no longer in balance and I'm about to replace it. Everything looks and sounds fine. I'm just curious if there's a certain mileage that's recommended for rod bearing replacement.
Thanks.
Old May 21, 2019 | 09:04 AM
DougR's Avatar
None that I know of for these engines under normal use or schedule 1 conditions as defined in the owners manual. If you have a very high number of cold cycles, instances of lugging the engine, high frequency of running to the redline, or running on the track or drag strip, then I think you should be doing an oil analysis to detect accelerating wear, and repair accordingly.
Old May 21, 2019 | 01:44 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Thanks.
You don't rebuild VQs. If it blows up, then you swap it. A 3.0 maintained will outlast you, anyway lol
Old May 21, 2019 | 03:52 PM
Cephyr13's Avatar
Great! Thanks for the info, guys. I'll leave them alone.
michaelliv
Oct 1, 2016 05:20 AM
STILO
Dec 30, 2009 11:07 PM
KRRZ350
Aug 11, 2007 09:07 AM
JClaw
Jan 17, 2007 07:44 PM
5thgenmaxima
Jan 25, 2006 04:08 AM
