Clutch Recommendations: OEM or 350Z for VQ30DE?
Old Jul 15, 2019 | 06:43 AM
Cephyr13's Avatar
I'm going to replace the clutch in my 2001 Maxima since I need to replace the rear main seal and tranny seal. It has probably 240 hp, so nothing special.
I've read thread here about using the 350z clutch kit, but I was unclear on whether that was only for the 3.5L motors or the if it applied to the 3.0 motors, as well.
I'd also like to know what are good brands that aren't expensive.
This car is a workhorse. It has lots of extra weight in it, so it's over 3800 lbs. I want to make sure I get a clutch that's going to last. The clutch it has right now is good, and is a cheap OEM replacement clutch, I'm guessing, but I'm not sure.
What would you guys suggest? Any good deals out there at certain websites?
Thanks so much.
Old Jul 15, 2019 | 07:05 AM
TallTom's Avatar
I went the OEM route and I am happy: Exedy clutch and Luk flywheel.
Old Jul 17, 2019 | 04:57 PM
Cephyr13's Avatar
Thanks, Tom. That's the way I'm leaning.
Cephyr13's Avatar
Is a flywheel really needed? I have over 200k on the car, but unless a flywheel is warped, I don't see a reason to change it.
Old Jul 17, 2019 | 07:21 PM
RA030726's Avatar
I'm nutty for Nissans
I had a OEM 2001 AE clutch in my 98 and my 99 has an Exedy stage one. I'd recommend either.
Flywheels are cheap. Since you will need to remove it to replace the oil seals behind it, just do it all and forget about it. Swap over your ring gear and timing ring.
As for the 3.5/350z thing, it won't work. They use dual mass flywheels and 6 speed transmissions.
Old Jul 17, 2019 | 07:29 PM
RA030726's Avatar
Don't forget there are 2 oil seals to replace; rear main seal and upper oil pan seal. I have a few pics of my clutch, flywheel and oil seal install:
https://maxima.org/forums/4th-genera...king-mods.html
Old Jul 17, 2019 | 09:59 PM
Cephyr13's Avatar
Thanks for the input. Much appreciated. I've never seen a car with the oil seal setup like this one. How odd. Thanks for that heads up.
carsnwomen91
18
Dec 24, 2014 12:20 PM
NYTooCooL
Aug 31, 2014 06:33 PM
nselca2
21
Apr 16, 2012 07:31 AM
imjustinlampe
May 29, 2011 06:23 PM
inspiredbykev
Mar 24, 2006 06:54 PM
