2002 Maxima GLE will not start
Old Sep 17, 2019 | 10:14 PM
Thumper1000's Avatar
no fuel in the engine- fuel pump was checked working correctly
battery is new and working
Problem seems to be the security system is shutting off the fuel pump and spark plugs
Mechanic suggested after a code indicated that the ECU was not communicating that we check the key first
Key was OK according to the electronic lock smith .
Ordered two ECU to have a back up
Put in the first replacement ECU same problem persists
electronic key mechanic came out read all the data and said in addition to the ECU the NATS appears to not be communicating
We located and replaced today
had locksmith back out he made a key to work with the NATS replacement (car started five times correctly and then stopped and gave a bad ecu code again
so we have three ECU , a replaced nats
any ideas on what could be triggering this code
Thank You
Old Sep 18, 2019 | 06:53 PM
DennisMik's Avatar
What is the exact code that is being generated? Without more precise information, your question is too vague.
In the meantime, Here is a link to the section of the service manual with the NATS security system info. Start reading on page 356.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EL.pdf
Old Sep 19, 2019 | 05:05 AM
Prophecy99's Avatar
thanks dennis, i was thinking the same,
illvillecat99
23
Dec 4, 2016 01:57 PM
cdoublejj
Oct 23, 2014 06:37 PM
Gillikanoosis
Apr 28, 2011 12:46 AM
Stagnet04
24
Sep 29, 2010 04:43 AM
adriena
Feb 14, 2008 02:23 PM
