safe mode
Old Oct 19, 2019 | 08:23 AM
sprikinzy's Avatar
safe mode
good day i have a 2003 maxima that goes into safe mode sometimes when i wash car, to get it out of safe mode i can either unplug the MAF sensor and it resets or i can reset the tranny and it drives good after that, any thoughts on this
Old Oct 20, 2019 | 12:25 AM
maxiiiboy's Avatar
Well, find out what's wrong with the car - when the problem occurs, check your codes!
Old Oct 20, 2019 | 03:59 AM
sprikinzy's Avatar
When this happens no codes show up have done scans before and after I reset
Old Oct 20, 2019 | 10:45 AM
DennisMik's Avatar
I don't understand how washing the car can cause this unless you have the hood open and are washing the engine.
So I have questions.
What is the car doing that you are calling it safe mode. I have never heard of safe mode without a check engine light.
Exactly how are you resetting the MAF and the trans?
Could you give some more details?
Old Oct 20, 2019 | 10:58 AM
sprikinzy's Avatar
It only happens sometimes when I wash the max. I unplug the maf and then plug it back in and car drives normal I can also reset by turning key to red light then press gas pedel down for a minute turn car off then wait two minutes start car and it drives normal I have also changed the maf sensor twice and it still happens. There are times after washng car that it works perfectly
Old Oct 21, 2019 | 12:52 PM
DennisMik's Avatar
What is the car doing (or not doing) that you are saying it is in safe mode? Is the engine running rough or does it run smoothly but not go over 2500 rpm?
Old Oct 21, 2019 | 01:48 PM
sprikinzy's Avatar
Car starts fine but when you engage into drive it does not get pass 2000rpm it like it's stuck in 4th gear with no power
Old Feb 20, 2020 | 06:19 PM
sprikinzy's Avatar
Safe mode
UPDATE ON my maxima so far i have changed the solenoids installed a ground kit cleaned all sensors changed plugs and transmission oil car works great very smooth acceleration purrs like a kitten BUTTTTT IT STILL GOES INTO SAFE MODE after heavy rains or sometimes when i wash it cant believe it now iam seriously thinking about AN ENGINE SWAP
Old Mar 15, 2020 | 02:42 PM
sprikinzy's Avatar
update on work done i changed out the brain and harness last week car works fine ,i washed it the day after change and no safe mode but washed car yesterday and wda it went back into safe mode i then switched off car turned it back on and it drives normal now /should i change the tranny or not
Rochester
Mar 25, 2016 10:07 AM
Rcrootbeer
May 22, 2014 09:11 AM
Klikzzz
Jan 23, 2012 08:26 AM
Cubanato
Sep 13, 2004 04:34 AM
JustTry
Aug 5, 2004 11:58 PM
