00' lower control arms.
My lower control arms are rusted out and the ball joints are shot. Ordered Mevotech replacements. They don't look the same as the originals. The originals have a three bolt plate covering the rear bushing. Will these fit underneath the plate? Are these (two bolt) replacements instead of the plate? I can't figure out if these need to be returned??!!
If they dont look the same then yeah something is wrong.
However, the 3-bolt plate is mounts to the control arm and you will swap it to the new unit. It has a round pin-like end that goes into the bushing.
The 3 bolts have to be removed from the car to do this job successfully and you swap the part.
Check YouTube. Prob videos. Be careful on reinstalling the bolts on the 3-bolt arm. They can cross thread if you get hasty with them.
Edit: actually I think there are 4 bolts on the pin-arm.
Is there’s a difference between the lower control arms on an SE, as opposed to the other models? Maybe this explains the difference? Unless I hear from the forum, I’ll just have to pull one side apart and compare, or see if this is a planned upgrade to the original part?
%@$& Haynes manual
Crisis averted. The Haynes manual has it wrong on a couple of counts. Firstly, I have no plate covering the aft control arm bushing...just like everyone else. Where they got that picture from, I have no idea. Second, they say there are three bolts on the pin arm...with a certain tightening sequence! I have four bolts.
Needless to say, the internet help videos and this forum have it right. I now have a shiny new left lower front control arm in place. The right one goes in today. Thanks for your input.
...huh i bought some cheap *** chinese kit with grease-erts on every thing, watched some youtubes videos and everything went on. even anti seized everything. just wish i knew what that loud creaking-ish rubbing -ish noise is when i drive with wheels at full loc.
EDIT: anyone have a pic of the plate, GLE does not have said plate?
You probably need to grease the turn stops. The turn stop is just a piece of metal presses against the control arm when you have the wheel fully turned. If the car is moving, the suspension/control arm moves up and down and you have metal rubbing on metal.
wxm
Apr 15, 2017 04:36 PM
LiGhtSoUt
Jan 7, 2008 04:17 PM
