Alternator Problems
Old Jan 19, 2020 | 09:58 AM
Damien Young's Avatar
Alternator Problems
Hi, I have a 2003 Nissan Maxima and I just replaced the alternator and ik the battery is good. The Pigtail has a broken clip but when I pushed it down with a stick to keep it tight the battery still died and I replaced the fuse on the battery. Does anyone know if the alternator has a relay?
This is the pigtail end that has a broken clip
Old Jan 19, 2020 | 04:54 PM
DennisMik's Avatar
There is no relay for the alternator. When you push the connector down, can you tell if all the wires inside the connector are pushed down into the connector and not sticking up?
Another thing to check is a 10 amp fuse that is under the hood in the box by the battery. the cover has the label ALT.S
What you need to do is check the voltage. If the battery is charged and ok, the voltage should read 12.5 volts before you start the engine. After you start the engine the voltage should be 14 volts, give or take a tenth or 2.
Let us know what readings you get.
Old Jan 26, 2020 | 10:41 AM
Fixed
It was bad ground wires they needed cleaned off.
UXMAX
Nov 11, 2016 12:26 PM
h2kFrosty
Jan 10, 2015 12:12 PM
DMad8724
32
Apr 6, 2014 04:24 PM
racin89lx
Jul 2, 2006 07:46 AM
nigfink
Nov 23, 2003 01:01 AM
