Idles out a lot
Old Jan 29, 2020 | 01:16 PM
Cephyr13's Avatar
Idles out a lot
You know how the 2000 and 2001 Maxima have that issue where the idle is irradic and it's due to the IACV going bad which blows a transistor in the ECU?
Well, does that problem ever have symptoms where the idle doesn't go high or irradic, but instead just idles out periodically?
My car is starting to idle out a lot.
Also, I changed the IACV and did a coolant bypass on it. Can that problem happen if a coolant bypass has been done?
Old Jan 30, 2020 | 02:13 AM
krismax's Avatar
Father of the 00 VI
My car idles perfect and i have done this on multiple cars. I think most idle problems are people playing with their cars and creating a vacuum leak.
Only a smoke test can find it.
Also it is possible the ECU is bad,many of these ECU's do not look burnt or have any smell,but are bad or going bad.
Old Jan 30, 2020 | 05:03 AM
Cephyr13's Avatar
Yeah, the car has a a vacuum leak I've been needing to track down and I figured this issue is related, but I wanted to check and see if it could be the ECU, as well. I'll fix the vacuum leak today and see if that fixes this idle issue.
Thanks.
MajorMax
Mar 18, 2014 08:07 PM
Tim018
18
Oct 1, 2013 04:31 AM
konak85
Mar 25, 2006 08:07 AM
jkmay01
Jul 22, 2005 09:27 AM
IceY2K1
May 31, 2005 10:39 AM
