Replaced clutch and flywheel now car won't budge. Goes into gear without pressing clu
Old Mar 17, 2020 | 05:42 PM
Mr.myster91's Avatar
2003 6spd won't move. Clutch pedal still firm. I am stumped. Throw some suggestions my way please. If it helps, the only gears there's any resistance are 5 and 6. Sounds like something spinning.
Old Mar 17, 2020 | 07:20 PM
freezer's Avatar
Did you confirm the clutch disc splines engage the input shaft prior to assembly?
Old Mar 18, 2020 | 05:35 AM
When you say this, are you referring to using the liner tool to make sure the clutch is lined up? I was under the impression that if that's the case then the tranny would automatically be in the correct spot.
Old Mar 18, 2020 | 05:45 AM
freezer's Avatar
I mean, did you at any point take the clutch disc and put it on the input shaft? Maybe you got the wrong disc (shaft size too big)
Old Mar 18, 2020 | 07:01 AM
no I didn't put it on the input shaft but the alignment tool was ordered for that particular model so wouldn't it be the same size? 😕
K20z1_rsx
Nov 13, 2008 06:43 PM
skweaky
May 30, 2007 09:54 AM
makavelisk
Jul 7, 2005 04:13 PM
mtrai760
Jul 2, 2003 12:33 AM
