Identify this sensor
Old Apr 15, 2020 | 08:24 PM
2KMaximaGLE's Avatar
Hello this is 2000 Maxima GLE, can anyone tell me the name of the sensor pictured(green clip)? Also could it have anything to do with my car being stuck in limp mode? Thanks for your time
Old Apr 15, 2020 | 08:56 PM
slvr2KSE5's Avatar
Air intake temp.
As for limp mode start by scanning for fault codes.
Old Apr 15, 2020 | 10:46 PM
Air intake temp.
thank you, I have scanned for codes, reader throwing nothing. I've also replaced the MAF sensor and throttle position sensor. I'm gonna try new spark plugs next, I'm not sure what else to do,
Old Jun 4, 2020 | 06:31 PM
TheVQ35's Avatar
did you try anything else? did it fix?
Old Jun 5, 2020 | 04:40 AM
guapoman2000's Avatar
I seriously doubt that the sensor you have pointed out is causing your Maxima in Limp Mode.
Limp mode is a Fail Safe feature from the ECM when "a" special sensor is not communicating correctly to the ECM......
Instead of filling up this thread, how about looking at Post #9 at:
https://maxima.org/forums/5th-genera...limp-mode.html
Best of Luck.
Old Jun 6, 2020 | 09:43 PM
The_Fixer's Avatar
Look for a post from tunermax2000 you have a 5th gen and the post from Akshun above is for a 5.5 totally different. Time to replace your iacv,TB and get a new ecu .
Old Jun 7, 2020 | 10:03 AM
cdoublejj's Avatar
i had my ECU repaired some years ago for the high idle issue caused by a bad iac, also replaced the throttle position sensor too have to do all 3 or it will fry again
alshamsi
Feb 12, 2020 04:54 AM
knock
Feb 6, 2015 11:05 AM
boondoxmax
Mar 20, 2014 07:00 PM
sterlingmaxima
Jun 17, 2005 09:07 PM
