ECM Gets 12v Puts Out 6v
Old Jan 28, 2021 | 09:02 AM
Violator's Avatar
I’ve tested all ECM power sources at the ECM terminals and the diagnostic k line only puts out 6v (also tested from right at the ECM)
VB(both)
SSoff
CRTN
IGNSW
Back Up (terminal 67)
all test fine at battery voltage (ssoff a few seconds after turning ign off). But my diagnostic k line is at 6.5volts. Car started acting super strange barely made it home. I feel like my ECM modules are tampered bc this just doesn’t make sense
Old Jan 31, 2021 | 08:35 PM
aackshun's Avatar
Grounds
where are your reading 6v?
Behind the radio is where the obdii grounds to.
The ecm grounds to the timing cover (two 10mms)
Old Feb 1, 2021 | 11:54 AM
Violator's Avatar
Originally Posted by aackshun
Grounds
even right at the ecm using the alligator clip extensions and the 10mms as my ground I read 6.5v.
Old Feb 1, 2021 | 04:43 PM
aackshun's Avatar
........... kay
Did you do anything about the ground behind the radio? (errm maybe behind cluster, i have too many maxima wiring harnesses in my head).
Eg. Get a wire brush, unbolt, clean, re-attach.
Also I'm assuming your ECU is receiving 12V into the main pins from the engine harness? You weren't clear on what exactly you tested which is why I asked.... "Where are you getting 6 volts from?"
I'm assuming the hot wire on the OBDII that was clear but you make it sound like you get 6v elsewhere as well....
Old Feb 1, 2021 | 05:56 PM
CMax03's Avatar
Let me know if you need a 5th Gen ECU I have an extra....
Old Feb 1, 2021 | 10:37 PM
DennisMik's Avatar
When you measured the voltage, was there something plugged into the OBD/DataLink port? It does make a difference. The FSM says you should measure pin 115 (K-line) with nothing plugged in. On 2000 & 01 cars, you should read 2 volts. On 2002 & 03 cars, you should read battery voltage.
The 6 volt reading doesn't match either spec for an empty connector. If there was something plugged in, reading the voltage with a voltmeter would not be accurate as the K line is a data communications line meaning the voltage is not constant, it is always changing. You need an oscilloscope to see the changing voltage levels. A voltmeter will give you a quasi average voltage reading.
Connect an OBD code reader to the car and see if it works. If you get information, I would not worry about the 6 volt reading you got.
Old Oct 2, 2024 | 09:14 AM
Nahum's Avatar
VB(both)
SSoff
CRTN
IGNSW
I Have a Nissan x trail from the k line network it show 6 volts Al the time no change. And my scanner doesn't connect
Old Oct 2, 2024 | 09:15 AM
Nahum's Avatar
It doesn't make sense that that's the only network it has
Stru
Apr 5, 2013 11:57 AM
CGMax97
Jan 21, 2013 04:40 AM
atriuum
18
Dec 29, 2012 12:31 PM
defdwight
Aug 10, 2008 05:50 AM
steve_max2000
Dec 16, 2003 03:45 PM
