Oil leak above the alternator
Old Feb 9, 2021 | 07:21 PM
maxinout93's Avatar
Ok so ive noticed that my alternator is coated with oil residue and dirt buildup. Im assuming its coming from the timing chain cover, its not necessarily a leak but more like a seep. Also the timing chain cover in that spot has what appears to be the rtv sealant hanging off, or coming off. Is there a way to seal it without taking to entire timing chain cover off??? 03 I35 by the way
Old Feb 9, 2021 | 07:31 PM
maxinout93's Avatar
As you can see the rtv is coming off
Old Apr 23, 2026 | 12:26 PM
Sleepyhawk's Avatar
I've got a similar issue with an oil leak somewhere on that side of the engine. Were you able to repair it?
Old Apr 23, 2026 | 02:24 PM
slvr2KSE5's Avatar
oil leaks can be repaired. most common cause is valve covers. second (only real other option) is timing covers. no, the timing chain covers can NOT be resealed without removing them.
Old Apr 23, 2026 | 04:36 PM
User1's Avatar
Valve cover. Common.
Little John
Jan 18, 2016 08:36 PM
Spencer5556
21
Mar 6, 2013 07:45 PM
snair2
Jul 18, 2005 08:12 PM
maximumsportZ
Dec 28, 2001 07:50 AM
