If the car sits long enough, does the factory alarm go off when the battery dies?
Old Mar 22, 2021 | 09:34 AM
TallTom's Avatar
I'm just wondering if the factory alarm goes off if the battery drops to a certain level.
I don't park near where I live (NYC life) so my battery has gone completely dead on two occasions when I didn't go take the car out for a spin. I know the alarm went off both times when I used my battery booster pack to help get the car started. I'm hoping that it doesn't go off when it's dying.
If it does, i will probably invest in one of the ground battery quick disconnects.
Old Mar 22, 2021 | 08:38 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It goes off when the V is too low on power restore.
Just leave a 10m wrench in the car.
Old Mar 23, 2021 | 05:50 AM
TallTom's Avatar
Good to know, thanks. I was worried it may have been like those old school aftermarket alarms that would go off when the voltage drops. I had a camaro that used to do that, LOL.
Old Apr 26, 2021 | 02:49 AM
StevieB's Avatar
Haha...thanks Tom,you asked a question I wondered about also. My Maxima is now my 2nd car and doesn't see much use. Wondered if I regularly wake the neighbours when the battery runs down.
Old Apr 30, 2021 | 07:13 AM
yellow_cake's Avatar
I'll add some info after gaining experience in the remote start / alarm business:
If the factory alarm is armed and the car loses battery power, on powerup it will still remain armed (saved in memory). So when the hood or door is open, the system will detect an intrusion and trigger the alarm.
Couple ways you can disarm the alarm:
  1. Unlock with factory fob, that should stop the alarm (granted I haven't tested this method on these cars).
  2. Unlock the driver's door using the key. The key lock cylinder contains a switch that sends an arm/disarm signal (with lock/unlock respectively).
Old Apr 30, 2021 | 09:09 AM
TallTom's Avatar
My battery was dead dead dead as could be so I did use the door lock to unlock to get in to pop the hood. Once i connected the booster, the alarm went off which makes sense since it was "armed" when the battery died.
Old Apr 30, 2021 | 06:21 PM
The_Fixer's Avatar
From years of installing alarms in maximas
Factory alarm does not go off if battery drains.it will go offf if hood is popped and car is jumped
Aftermarket alarm will go off(Viper) if battery drops below 9 volts one of the reasons Viper added a auto start function when it senses low voltage.
Vipers will drain the battery unless you add 10a diodes on all the power connections and start wires.
Old Apr 28, 2025 | 11:42 AM
gregs2003's Avatar
Alarm sounds when battery is connected
Thank you!! This is the key piece of information I needed to stop the alarm from going off when I connected the battery. The car sat for 3 months and the battery was completely dead. I disconnected it, it was reading 3 volts. Then charged it and reconnected. Alarm went off and could not be silenced using key fob. To fix, I disconnected positive battery terminal and ran wires from battery + and the car's battery + connector. This is so I could close the hood, then apply power to the car's electronics with hood closed. After making the connection, the alarm system went off, but I was able to silence it with the key fob. Then reconnected battery and started the car.
So for this case, the bottom line is put the car back into the state it was in when the battery died. Then apply 12V to power up the car's electronics. Alarm sounds, but can be turned off with key fob. I probably could have just held down the hood switch ...
Old Apr 29, 2025 | 07:06 PM
Bad *** Newb
That's weird. Using key to unlock door has always worked for me.
I guess I never armed them and let em sit. But I know if battery is low and I reconnect, it will always go off.
The Wizard
32
Mar 3, 2021 04:25 PM
SE01
Sep 28, 2004 01:45 PM
trey
Sep 13, 2003 02:40 PM
kingrye
Apr 5, 2003 11:48 PM
