Got a Fuel question?
Old Jul 7, 2021 | 08:29 PM
cwmccray_jr's Avatar
I recently got a 2002 Maxima SE started after sitting for over 6 years. I had to replace the fuel tank and the fuel pump. This also included filter also.. The tank was filled with fuel that looked like sweet tea. Once I got it cranked. I got obd2 codes of 340, 345, 183, 463, 1800. I replace both of the camshaft sensors in the heads. I also replaced the thermostat and drain the cooling. I also replaced the Variable Intake Air System Control Solenoid Valve and I have replaced the fuel pump temperature sensor... Am I missing something? Each time I turn the key over the fuel pump pulses... No fuses are blown and I have replace the fuel pump relay twice.. Both being good. When I was at a drive thru waiting.. It cut off. It now only cranks if you spray starter fluid in the filter box.
I had a mechanic friend of mine with a snap on computer had issues at first reading the computer. Then he got it to read the ECM. So for a minute I was assuming that the ECM might be bad.. Has anyone else had this issue?
Chuck McCray
02 Maxima SE
03 Escalade
99 BMW 740il
NZ 4th gen cefiro
Nov 17, 2019 02:03 PM
MaximumRPM
Dec 29, 2015 04:18 PM
tallkid2201
Mar 28, 2008 06:41 PM
RyCrisp
Jul 19, 2006 06:02 PM
Danny95
Mar 31, 2004 04:45 PM
