Is this a bad motor mount
Old Aug 15, 2021 | 09:11 PM
hithesh's Avatar
I am trying to figure out if vibrations at traffic light is because of a bad engine mount.
I was able to get pic of the driver side engine mount. Is this how a good one looks -
Old Aug 16, 2021 | 07:20 AM
uptownsamcv's Avatar
it's not missing any rubber but it does look old. when in doubt change them all. I highly recommend the energy suspension mount kit for the 2 lower mounts. if your car is automatic you will need to obtain a rear manual engine mount.
Old Aug 16, 2021 | 09:07 AM
Prophecy99's Avatar
the mounts that do most of the work on these cars are the front and rear mounts. if you are thinking about them, it probably is time to replace them. i just replaced my original mounts at 275k miles with Energy suspension bushings and the increased vibrations from the poly mounts were not bad at all, and car drove and shifted like a new car., i would take the extra vibrations for the better feel and performance from them vs stock mushy ones for no vibrations. i daily drive too.
Old Aug 16, 2021 | 05:04 PM
hithesh's Avatar
How do you fit the energy suspension into the metal brackets?
Can it be done by hand (not superman)?
Old Aug 19, 2021 | 05:23 PM
User1's Avatar
You can download the installation instructions from their website.
Old Aug 21, 2021 | 05:26 PM
Theslaking's Avatar
A local shop pressed my mounts in and out for $40 a couple weeks ago.
Old Aug 23, 2021 | 12:15 AM
SquidBeak's Avatar
ES engine mounts won't solve your left/right mount problems if they are shot, but they are a great upgrade.
It is a challenging job but not overly difficult. You will have to drop the cross member to get the front and rear mounts out. Once you have the mounts out, the difficult part is getting the old rubber bushings and their surrounding metal cylinders out of the mount frames. It isn't really that hard, but it's tedious. It can be done with a hacksaw.
Once the old rubber bushings are out, you can press in the ES poly bushings with a vice about 90% of the way and a rubber mallet for the remaining 10%.
02whitemaximase
Nov 17, 2012 06:30 AM
FenderGuy
Jan 14, 2012 04:08 PM
luke95gxe
May 27, 2011 07:00 AM
