M-Pact clutch
Old Dec 1, 2021 | 02:03 PM
uptownsamcv's Avatar
M-Pact clutch
recently I installed an SE-R spec V H-LSD along with JWT flywheel and decided to try the M-Pact clutch components they sell on www.rockauto.com. the latest year Z that they list separate pressure plate and disc for is 2006, which should be good enough for bolt-ons and ecu reflash for 02 maxima. the pressure plate part number is M-PACT 98630 which is also their pressure plate listed for 02-06 Maxima. the disc part number is M-Pact 99688D which is their general sprung organic disc for many other Nissans and G35. I went with a National throw-out bearing and pilot bearing this time.
after putting 500 miles of city driving for break in I finally started getting on it yesterday and it has a lot more bite than the outgoing basic Luk kit I was running.
I also replaced the flywheel bolts with Allen head bolts with orange loctite, I hate torx bolts. Only Fastenal had the Allen head bolts that matched up. JWT instructions called for Loctite red but I don't think it's a good idea to use it on a crank. the flywheel will need to come off eventually, mainly when I do the 2nd gen swap.
double springs on the clutch disc
outgoing flywheel and clutch components
Old Dec 2, 2021 | 01:18 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Very good price for clutch kit as long as it holds up. Looks solid.
Old Dec 2, 2021 | 08:17 PM
all the clutch components together ended up costing me $168.97 which isn't bad, now it's just a matter of how good it holds up. My lust clutch kit was an LUK that came packaged with an LUK dual mass flywheel, not Exedy as I mentioned above. when I first got my car in December of 2012 the throw-out bearing went bad a month later and I had installed an Exedy kit.
Nisformance had the JWT flywheel on sale for $398 a few weeks ago when I ordered it
M-pact pressure plate #98630 $82.79
M-Pact friction disc #99688D $60.79
National release bearing #614049 $23.79
national pilot bushing #PB22 $1.60
I only paid $300 for the 04 Sentra SE-R Spec V donor tranny that I took the Helical LSD out of. it fit right in since it's the same LSD that comes in some of the 6 speed Maxima's, I just had to put the Maxima's ring gear on it. I would have swapped the whole gear set like I saw in some write ups but my tranny doesn't grind any gears so I kept the stock gears.
Old Dec 3, 2021 | 12:47 AM
Bad *** Newb
Originally Posted by uptownsamcv
all the clutch components together ended up costing me $168.97 which isn't bad, now it's just a matter of how good it holds up. My lust clutch kit was actually an LUK that came packaged with an LUK dual mass flywheel, not Exedy as I mentioned above. when I first got my car in December of 2012 the throw-out bearing went bad a month later and I had installed an Exedy kit.
Hmmm, my exedy's came with OEM bearing.
Old Dec 3, 2021 | 05:21 AM
I believe I have ran 4 different types of throw-out bearings over the years ( 2nd one came from Nissan) and I'm starting to think they all are made by 1 company since all of them contain plastic, SMH.
Old Dec 3, 2021 | 09:22 AM
RA030726's Avatar
I'm nutty for Nissans
Where is the M-Pact clutch made?
Old Dec 3, 2021 | 12:30 PM
not sure, the box is long gone. I'm guessing it's made in China like everything else.
Old Dec 4, 2021 | 06:00 PM
User1's Avatar
Looks clean. Refurbing and reconditioning the pedal hinge, fluid, master cylinder, all the engagement parts leading up to it will give it a nice feel too.
Old Dec 5, 2021 | 06:39 AM
i had already had put in a new master and slave as well as a Nisformance clutch line that eliminates all the unneeded metal lines that Nissan put in. I haven't messed with the pedal hinge though.
matts95max
Mar 22, 2009 07:00 PM
MaXtUneD
Dec 10, 2004 06:19 AM
95_SE_5spd
23
Sep 22, 2004 03:42 PM
SonicDust187
Jun 25, 2004 09:52 PM
