Engine floods after failed start in cold weather
Old Jan 3, 2022 | 11:12 AM
Mharvey500's Avatar
Hi, I haven't found a post that quite describes my problem, which is not a serious problem but may be leading to one. There are two factors to this: 1) the cold weather is upon us, 2) I have a habit of cranking the engine to short a time because starter makes horrible noise if it is dragged by the flywheel (this is not a problem). So the engine fails to start sometimes because I don't crank it long enough. The second crank takes a while to start, not instantaneous like the first start should be. So now that it is cold, -8C, the second crank is taking maybe 10 seconds and there is tons if smoke from the exhaust. My guess from reading other posts is I need new injectors. Is this a reasonable suggestion?
Old Jan 3, 2022 | 01:00 PM
User1's Avatar
Pull codes and replace your starter.
Old Jan 3, 2022 | 02:27 PM
Mharvey500's Avatar
The engine light is not on.
Old Jan 4, 2022 | 04:43 PM
User1's Avatar
Oh ok then everything is fine. You don't have a problem.
Old Jan 5, 2022 | 03:00 PM
uptownsamcv's Avatar
I'm guessing -8 degrees would cause fuel not to flow so great.
I couldn't live anywhere that I would have to deal with snow. my car is rust free and I can ride my motorcycle all year round.
Old Jan 5, 2022 | 04:50 PM
Child_uv_KoRn's Avatar
Bad *** Newb
-8F isn't cold for gas engines and -8C (his temp) isn't cold at all lol
Sounds like the usual cam/crank sensor bull**** to me.
Old Jan 5, 2022 | 04:54 PM
Mharvey500's Avatar
My guess about the fuel flow in a 21 year old car in cold weather is rubber seals stiffen up in the cold and leak after the first start fails. In particular I think it is one injector because my engine knocked pretty bad on one cylinder like the gas washed away the oil. Love to ride motorcycle but not at my age, tempted many times.
Old Jan 5, 2022 | 05:10 PM
Bad *** Newb
Maybe FPR is leaking down. He can test that just by priming the pump a few times before attempting to start. Temp hasn't mattered in my experience.
Old Jan 5, 2022 | 07:24 PM
User1's Avatar
Which would be either an active or pending code with/without a CEL on the dash but what the hell do we know
Old Jan 5, 2022 | 11:03 PM
Bad *** Newb
You would hope, but experience also says it doesn't have to.
Old Jan 5, 2022 | 11:10 PM
User1's Avatar
They ask, you try to help, and they shut you down. He doesn't have a dash light, therefore he doesn't need to pull codes. Codes that wouldn't necessarily trip a dash light. So whatever. You guys deal with him Lol
Old Jan 5, 2022 | 11:21 PM
Bad *** Newb
Are you saying pending codes don't throw lights? HERESY
Oh, I forgot to mention: If starter is grinding, then it's throwing off shavings that will stick to crank sensor. What do you think metal shavings do to a Hall effect sensor?
Old Jan 5, 2022 | 11:27 PM
User1's Avatar
Good call. Shavings will jam you up man
Old Jan 6, 2022 | 06:44 AM
Mharvey500's Avatar
I appreciate your help. I will be looking for codes and testing for leaking FPR.
About the starter it's make a screeching sound since new and I was told there is nothing wrong. It happens because there is not lubrication in the shaft that the gear will rotate on before it can retract from the flywheel. That's why my first start attempt often fails because I am in the habit of shortening the crank attempt to get the gear retracted before the engine fires up.
Old Jan 8, 2022 | 03:43 AM
Mharvey500's Avatar
Not sure if I'm doing this right, but I turned key to on position just before the start position several times to prime the fuel pump. After that it started like a charm so I guess FPR is not leaking down. This is at -12C.
Also no pending codes.
heuster
18
Nov 19, 2018 06:17 PM
blazingchimp
May 21, 2007 07:48 AM
djx82
Apr 25, 2005 07:02 PM
crazixpaki
Jan 21, 2004 04:15 PM
vxn12
Dec 24, 2003 04:14 PM
